Grill install
Old Feb 15, 2006 | 05:05 AM
neptune_'s Avatar
Default Grill install
Hi folks... I'm looking for some 'installation for dummies' instructions on how to replace the front grill on a 2000 Civic sedan.
The original has been vandalized and I have a replacement to put in.
Thanks!
Old Feb 15, 2006 | 05:52 AM
MikeD718's Avatar
Default Re: Grill install (neptune_)
take off your front bumper and remove the screws from the bottom of the grille. replace with a new one and put the bumper back on.
Old Feb 15, 2006 | 06:00 AM
neptune_'s Avatar
How do I take off the bumper?
How exactly do I remove and re-install the grill?
You didn't really provide any useful information or step directions
Old Feb 15, 2006 | 06:46 AM
snatch's Avatar
Default Re: (neptune_)
1. Get under the car, remove the 2 bolts holding on the bumper and the 2 screws. (They will be towards the middle and outside, respectively)
2. Remove (1) screw in each wheelwheel. Look at where the bumper meets the fender, you will see a socket head screw.
3. Pop hood
4. Remove all pins along the top of the grill with by using a flathead screwdriver to remove the pin, then pulling up on the insert.
5. Remove bumper.
6. You should be able to figure out how to remove the grill by looking at it, I think there are a couple of screws on the backside holding it on.
7. Installation is the reverse.
Whatislove
Honda Civic (2001 - 2005)
18
Sep 10, 2009 05:55 AM
luckyguess
Jan 8, 2008 03:57 PM
95se4dr
Aug 5, 2004 10:39 PM
slowone
Jun 26, 2003 02:09 PM
Lewd Lude
Jun 22, 2001 02:46 AM
