0-60: 8.4 sec .. good or bad?
I'm running a d16y8 with h/i/e
manual tranny (S20)
Stock Ecu (Automatic Ecu, didnt change it after swapping a manual tranny)
Broke Engine mount (1 mount)
Broke Tranny mounts (2 mounts)
The Clutch aint that good although its oem clutch
My 0-60 is 8.4 sec's launching @ 5k rpm .. is it good or you think it should be better?
manual tranny (S20)
when I 1st read topic title, I thought it meant quater mile, 8.4 seconds, good or bad? I was like: "is this guy on meth?"
It's good for what you have wrong with it, u should definately consider replacing the mounts..
i think you could do better, i have a d15b vtec (basicaly the same as your set up, performance wise) i got an 8.3 with a passenger and winter tires in sub-zero weather, with a very easy launch.
My y7 does about that, and I got the bolt ons too.
Your time seems just about by the book. Fix your motor mounts, and maybe a replacement clutch may help.
ALSO, get better tires, cause 5,000 RPMs is gonna wreak havoc on your clutch. Killing your clutch isnt worth an extra tenth of a second. Go to 3,000 I say and engage quickly then floor it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Right or not, thats slow.</TD></TR></TABLE>
Very true.
Why do you want to know if it's right or not? Are you wondering if there was work done to your motor before you bought the car, or are you trying to figure out if you have severe problems other than the mounts and stuff?
How did you measure the time... Gtech?
Very true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 278civ »</TD></TR><TR><TD CLASS="quote">i think you could do better, i have a d15b vtec (basicaly the same as your set up, performance wise) i got an 8.3 with a passenger and winter tires in sub-zero weather, with a very easy launch.
What rpm do you use when your launching your car for a test ?
</TD></TR></TABLE>What rpm do you use when your launching your car for a test ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX »</TD></TR><TR><TD CLASS="quote">Go to 3,000 I say and engage quickly then floor it.</TD></TR></TABLE>
I'll try that
Thnx for the info mate
I'll try that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSaura »</TD></TR><TR><TD CLASS="quote">Why do you want to know if it's right or not? Are you wondering if there was work done to your motor before you bought the car, or are you trying to figure out if you have severe problems other than the mounts and stuff?
How did you measure the time... Gtech?</TD></TR></TABLE>
I asked just to know if i'm doing 0-60 as the d16y owners do or not
just to make sure that everything is fine and my motor is working fine
and about measuring the time i used an stopwatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">holy crap i thought he meant his 60footers LOL</TD></TR></TABLE>
yeah, i thought 0-60 was a car and driver/manufacturer test thing only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 278civ »</TD></TR><TR><TD CLASS="quote">i just launched at i think 2k or so.</TD></TR></TABLE>
try revving to 3.5k-4k and slip the clutch.
Hahaha, exactly what I thought. I was like, damn, are you dragging in the snow or something!?
GarageAlchemist
May 24, 2006 10:57 AM
jazz215
Jul 16, 2003 11:28 PM
