What is this plug?
Run the VTEC solenoid wire to pin A4 on the ECU. Run the VTEC pressure switch to pin D6 on the ECU. Connect the pressure switch ground wire to a good ground.
Do I do this instead of hooking it up to the plug in the back of the block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 »</TD></TR><TR><TD CLASS="quote">Run the VTEC solenoid wire to pin A4 on the ECU. Run the VTEC pressure switch to pin D6 on the ECU. Connect the pressure switch ground wire to a good ground. </TD></TR></TABLE>are you OBD0 or OBD1? those pinouts are for OBD1 - OBD0 is VTEC solenoid to A8, pressure switch to B5, 1st O2 to C16 and 2nd O2 to C8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by konrad »</TD></TR><TR><TD CLASS="quote">also what ecu are you running? I believe some obd0 jdm b16 ecu's don't need the pressure switch to engage vtec.</TD></TR></TABLE>
sounds mysterously, since the pressure switch is the thingie that activates vtak! Unless you got the Flux Capacitor, ofcourse.
without the pressure switch? How does the car know when to activate vtec then? At my best knowlegde, the vtec is oil pressure driven. ergo, it needs an oil pressure switch that activates at given pressure.
over to the question at hand. If this is a swap with obd0 system you could be needing this.
http://rywire.com/store/produc...b9147
Thanks bro. I ended up reading some page that has the real directions here it is. Look what it says under wiring vtec about 70 percent down
http://www.norcalcrx.org/dropp...p.htm
Awsome site for dropping a b16 in
89sparks
Sep 4, 2007 06:35 PM
nutball72
Aug 26, 2006 10:54 AM
ahthisguyhere
11
Apr 24, 2006 04:22 AM
I dont question you, it just doesnt sound logic to me. Thats all. I will dive into the matter.
