no dash lights in 91 civic hatch,tried everything
Old Feb 14, 2006 | 11:32 PM
skiracer8148's Avatar
Default no dash lights in 91 civic hatch,tried everything
i have check all fuses they are all good.the only thing that works in the dash at night is the clock.i have also i tried to chang the dimmer they still dont work.anything else i should check?if i have to what are the main wires to illuminate the dash i can wire them up otherwise
Old Feb 15, 2006 | 04:07 AM
88turdbucket's Avatar
Default Re: no dash lights in 91 civic hatch,tried everything (skiracer8148)
are your taillights out to, usually when your gauge lights go out so do your tails, but that would have been a fuse issue at that point.
Old Feb 15, 2006 | 05:19 AM
123_vtec's Avatar
Checked the bulbs in the gauge cluster? And you meant the whole dash lights dont work like the light in the climate control, the light in the gauge, etc.? If so, check the fuse again, make sure they are in good condition and in places they are supposed to be in. Then check out the bulbs, you could have had a short and burnt out the bubls. Just a thought. Good luck.
Old Feb 15, 2006 | 01:31 PM
didnt check the bulbs yet just figured it was something else because the whole dash lights are out
Old Feb 20, 2006 | 11:04 PM
anyone kno what the pin outs are on the cluster so i can run a switch to them?
shoebox
Sep 28, 2012 04:39 AM
ChilBlu92
Feb 25, 2009 11:00 AM
[tk4L] Doke
Oct 4, 2006 11:38 AM
Ham'ed Hatch
May 22, 2003 09:25 AM
