what fan to use with b16 91 civic
Old Feb 14, 2006 | 11:26 PM
skiracer8148's Avatar
Default what fan to use with b16 91 civic
there doesnt look like there much room and there is no fan will the stock fan work?
Old Feb 15, 2006 | 12:07 AM
StorminMatt's Avatar
Default Re: what fan to use with b16 91 civic (skiracer8148)
You will have to give it a try. If it won't work, you will have to go custom.
Old Feb 15, 2006 | 12:37 AM
soulfly's Avatar
u mean the radiator fan? i had no problem with mine.
i'm using DA8 double layer radiator with two fans
Old Feb 15, 2006 | 05:59 AM
Black4thgenEF's Avatar
Default Re: (soulfly)
Stock fan and rad with my B16 and plenty of space.
Old Feb 15, 2006 | 08:19 AM
JDMCivicEF9's Avatar
Default Re: (Black4thgenEF)
Well, you can try a slim fan. 10" - 12" fan is good enough. Theres a sale on the Performance section of Honda-Tech.
Old Feb 15, 2006 | 08:54 AM
k20rex's Avatar
in my old crx with b16 it had two fans i had to take the one close to the header out and only have one, then i got a si del sol radiatior with the fan it is alumimum and alot smaller looks better and should give you the clearance you need
Old Feb 15, 2006 | 10:50 AM
civickiller's Avatar
Default Re: what fan to use with b16 91 civic (k20rex)
yeah the one infront of the header is for the ac. i took mine out because it put a hole in my radiator and it was a tight fit
Osbjoey
Jul 3, 2012 05:20 PM
lengleng
Aug 12, 2006 05:52 AM
6MTV6
17
Jun 22, 2004 07:02 AM
BdoubleU
Oct 27, 2003 08:38 AM
austrian type-R
Mar 12, 2003 04:31 PM
