90 accord, oil in spark plug hole -- what's that mean???
Old Feb 14, 2006 | 10:31 PM
e_r_i_c_'s Avatar
Default 90 accord, oil in spark plug hole -- what's that mean???
went to change my plugs and there is oil in there -- enough to get about a half inch on the plug wire when i stick it in... is that a bad gasket or what -- and what is the fix???
thanks
Old Feb 14, 2006 | 10:43 PM
YeuEmMaiMai's Avatar
Default Re: 90 accord, oil in spark plug hole -- what's that mean??? (e_r_i_c_)
time for some new tube seals. You can get them as part of a kit that will replace the
valve cove gasket
tube seals
grommets
if you have not had a valve adjustment done recently, now is a good time to do it.
Old Feb 15, 2006 | 07:36 AM
conker's Avatar
Easy fix, pop the valve cover off and look inside of it. Around each spark plug opening is a rubber o-seal (some may have stuck to the head). Pull them out, pop in 4 new ones (couple of $$ each at the dealer or included in the gasket kit mentioned above). Reinstall cover, done.
Old Feb 15, 2006 | 11:28 AM
92ehatch's Avatar
Default Re: 90 accord, oil in spark plug hole -- what's that mean??? (conker)
there is a great writeup on cb7tuner.com for replaceing those spark plug tube seals.
i was able to do it myself without issue.
basically, go buy a new valve cover gasket kit from advance (like 16 bucks)
then take off valve cover with 4 acorn nuts (7 ft lbs)
take off grounding skrew and plug wires, label them so you know where they go. as well as spark plugs
take off any other pieces on valve cover and remove it.
now you have to take off the rocker arm assembly,
i forget the trq specs on these bolts
before you remove the rocker arms its a good idea to loosen the valves to take off any unnecessary stress caused during the process.
take a rawhide or soft hammer to help remove the assembly.
replace o rings, put rocker arms back on and trq to spec
valve adjustment comes next
then put all back together.
sorry for the low detail, im trying to do this by memory, just search cb7tuner forums for the writeup, its labeled ENG: spark plug tube seals or something like that.
they have pictures, trq specs, valve adjustment info.
good luck with it
Old Feb 15, 2006 | 11:31 AM
92ehatch's Avatar
http://www.cb7tuner.com/vbb/sh...seals
i had it bookmarked
Old Feb 15, 2006 | 02:15 PM
t3952's Avatar
it's one of the "O" rings that is leaking in the valve cover, change your head gasket and the four rings come with the new gasket
Old Feb 15, 2006 | 07:08 PM
BLKFLSH's Avatar
Default Re: 90 accord, oil in spark plug hole -- what's that mean??? (t3952)
It could be just the doughnuts under the valve cover. But most likely it's the orings under the rockerarms. Use the link above for instructions.
zedjr
Jan 30, 2013 10:14 PM
lgharis
May 23, 2007 06:10 PM
loup05
Jan 28, 2006 05:30 PM
amir904
Aug 12, 2005 07:45 AM
redpeppers
Jul 15, 2005 04:17 AM
