compressing air
Does compressing air make the air hotter or is it the thermal dynamic effect of the heat of the engine has on the air that is compressed?
Modified by 92 CIVIC HATCH VX at 11:24 PM 2/14/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX »</TD></TR><TR><TD CLASS="quote">Does compressing are make the air hotter </TD></TR></TABLE>
We dont put intercoolers after turbochargers for looks now
yes it does.
Some stupid gas law.
yes it does. Some stupid gas law.
straight outta physics23 I had about 4 years ago....
PV=nRT
Pressure*Volume=moles(atoms I think?
)*gas constant*Temperature
With all things being equals just raising pressure (compressing since it's the same volume) then Temperature will rise
. This is true for real world turbos as well along with wheel efficiency (nothing to do with sizing)
PV=nRT
)*gas constant*TemperatureWith all things being equals just raising pressure (compressing since it's the same volume) then Temperature will rise
thanks yeah i knew the intercooler was there to help the density of the air.
looking forward for my turbo build soon.
god i got so many things to calculate.....or i can just start throwing parts on my motor and hope i make good power...j/k
i know the manifold plays a big part of turbo and getting the flow right.
i got a lovefab mini me EQ i was going to get it swains coated and wrap it.... maybe double up on the heat. should i make the dump tube recirculate back in to the down pipe?
Modified by 92 CIVIC HATCH VX at 10:16 AM 2/15/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">straight outta physics23 I had about 4 years ago....
PV=nRT
wow, im pretty impressed, someone payed attention...or did a little extra cericular activities with the teacher...
PV=nRT
</TD></TR></TABLE>wow, im pretty impressed, someone payed attention...or did a little extra cericular activities with the teacher...
I'd like to add that turbo sizing also plays a role in heat. A compressor and compressor wheel size play a huge role in heat. A smaller turbo will obivously spool up faster due to turbine size and AR, but since the compressor wheel is also small it becomes inefficient at "compressing" the air so the air heats up. A larger turbo although has more lag can compress larger amounts of air more efficiently. This is why turbo sizing is important. Once your power goals are figured out and you calculate how much CFM your going to need try to find the turbo that will be most efficient in that area and maybe a little room to grow for later on if you plan this.
beaterdriver
Mar 17, 2004 07:51 AM
