Header Pipe nut frozen
Old Feb 14, 2006 | 08:59 PM
dan_g's Avatar
Default Header Pipe nut frozen
I am trying to unscrew the 3-14mm nuts that are screwed to the header pipe. I am in the process of changing the oil pan gasket.
I used a 14mm deep socket + breaking bar and it started slipping. I dont want the nuts to get rounded. Is there a way or another type of socket to loosen it?
93 Civic 4 Dr LX, Auto, 175k miles
Thanks
Old Feb 14, 2006 | 09:11 PM
Banned HT Member's Avatar
Default Re: Header Pipe nut frozen (dan_g)
try spraying some wd40 on the bolts and let it set for a couple hours, a day would be better, should help
good luck
Old Feb 14, 2006 | 09:16 PM
qat727's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan_g &raquo;</TD></TR><TR><TD CLASS="quote">I am trying to unscrew the 3-14mm nuts that are screwed to the header pipe. I am in the process of changing the oil pan gasket.
Thanks
squirt some PB Blaster on them and let it sit for a while. If that fails and you can't get them off w/o stripping them, check and find the the next smaller size in the SAE equivilant socket and knock it on there and bust it loose.....
That or just take a torch to it, get it hot, and then unscrew it.... Or just get the engine nice and hot, then try...
Old Feb 14, 2006 | 09:20 PM
SixguN's Avatar
Default Re: Header Pipe nut frozen (qat727)
Hit that **** with a hammer to knock off any loose rust before you spray it, I always do...
Old Feb 14, 2006 | 11:31 PM
nello a.'s Avatar
"PB Blaster" and time. maybe impact wrench.
Old Feb 15, 2006 | 12:05 AM
Rubixcu7's Avatar
pb blaster and let it soak
Old Feb 15, 2006 | 12:56 AM
jdmpremonition's Avatar
we did all that and more to my friends prelude we ended up having to cut them off...
Old Feb 15, 2006 | 04:32 AM
EGNA's Avatar
they sell sockets made for stripped bolts, id definately invest in some....theyll save your life over and over
Old Feb 15, 2006 | 04:52 AM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 &raquo;</TD></TR><TR><TD CLASS="quote">
That or just take a torch to it, get it hot, and then unscrew it.... Or just get the engine nice and hot, then try... </TD></TR></TABLE>
i like where his head is at.
Old Feb 15, 2006 | 05:48 AM
Everyones Hero's Avatar
Default Re: Header Pipe nut frozen (THC1107)
Just go at it with a grinder.
If your car is anything like mine was those bolts are not coming off.
Old Feb 16, 2006 | 05:08 AM
dan_g's Avatar
Update:
Thanks to all of you. I sprayed WD40 when the engine was a little hot, had to remove the heat guard. 6 hours later managed to unscrew it with a breaker bar and some extra muscle. This weekend I will change the oil pan gasket.
I dont want to open another thread but I have a few questions.
1)The PCV valve is located at a wierd place how do you remove it . Do you have to pull the hose from under the intake manifold and then pull the PCV from top? or - - -.
2) I want to degrease the arrea around the engine. Is there a good product for this?
Thanks again
Dan
uberEFtuner
Jun 29, 2011 08:21 PM
SleeperGSR
Jun 23, 2011 05:08 AM
jacoop86
Mar 15, 2006 01:01 AM
Shaka01
Feb 28, 2006 02:58 PM
sshaikh01
Nov 8, 2003 11:15 AM
