SOHC 600rr ITB's
I just picked up a set of these and am wondering if there is any advice before I start at making ITBs. Any general stuff would help (vacuum stuff, injector info, etc.) along with engine managment. I want crome but I have no idea on ECU or anything, I have a 96 Del Sol with a y8 in it... OBD2a
nobody's gonna really help you until you search.....
There is literally chapters of information on this subject in recent and archived history.
Best of luck on your project.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianDelSol »</TD></TR><TR><TD CLASS="quote">I did search, none of this came up, I looked on d-series.org too, there is nothing. Did you search? </TD></TR></TABLE>
That's a trick question right?
Try going to search....entering ITB and then select archived content and the all motor forum.
Tell me how many links you come up with.
Another "search" guy. Why waste your time to tell him that... Just move on.
This might help: https://honda-tech.com/zerothread?id=1191757
CBR600's 36mm or 38mm throttles are really too small to efficently breathe on a D motor. These were originally designed for a motor with less than 1/2 the displacement of your D motor. You really need to look at 929 or 954 itb's if you want to make good power from your motor. As stated before, just type ITB in the seach page and you will have more than enough info for your ?s.
https://honda-tech.com/zerothread?id=360311
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianDelSol »</TD></TR><TR><TD CLASS="quote">I just picked up a set of these and am wondering if there is any advice before I start at making ITBs. Any general stuff would help (vacuum stuff, injector info, etc.) along with engine managment. I want crome but I have no idea on ECU or anything, I have a 96 Del Sol with a y8 in it... OBD2a
I found these that are helping me...
https://honda-tech.com/zero...age=2
Modified by busychild at 9:07 PM 2/18/2006
JdmLub
May 20, 2006 01:48 PM
