check engine light blinking?
Old Feb 14, 2006 | 07:28 PM
tpod's Avatar
Default check engine light blinking?
usually when the ecu would throw a code before the yellow check engine light would be solid, but now it just blinks every couple seconds, also it isnt always like this, just randomly. i have searched but still now sure.its a 90 crx with b16 obd0 thanks in advance
Old Feb 14, 2006 | 08:35 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: check engine light blinking? (tpod)
could have a short to ground thats maknig the light flash.
Old Feb 15, 2006 | 10:25 AM
tpod's Avatar
Default Re: check engine light blinking? (DieMaster)
allright, anyone else
Old Feb 15, 2006 | 10:52 AM
EF9ZC's Avatar
could be anything say a short in a sensor like ur tps is half way plugged in
Old Feb 15, 2006 | 08:40 PM
tpod's Avatar
hmm, thanks, ill check it out tommarow
Old Feb 15, 2006 | 08:41 PM
e jay one's Avatar
Default Re: (tpod)
check what the cel is for?
Old Feb 16, 2006 | 09:35 PM
jdeemseerx's Avatar
is it only at high rpms? if so its your knock sensor i had the same thing happen to me i believe its code 23 check the sensor itself to see if its tight then go for the wiring good luck
Old Feb 17, 2006 | 08:01 AM
tpod's Avatar
Default Re: (jdeemseerx)
no it seems like it happens randomly even at idle sometimes. i havent checked the ecu because i put the cover back on while ago and havent had time to take it off.
Old Feb 17, 2006 | 10:57 AM
socalef9's Avatar
Default Re: (tpod)
dud i had the same thing happen to my car, i swapped my motor from one car to another and when i drive, i get a blinking cel and no code. i checked ad rechecked my connections so i got fed up and just clipped the cel wire, its not the best thing to do but every now and then i just check my ecu.
Old Feb 17, 2006 | 06:41 PM
tpod's Avatar
Default Re: (socalef9)
damn, allrite, i checked most of the connectors and everything was tight, no cel yet, hopefully it will stop.
Old Feb 17, 2006 | 08:01 PM
DieMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalef9 &raquo;</TD></TR><TR><TD CLASS="quote">dud i had the same thing happen to my car, i swapped my motor from one car to another and when i drive, i get a blinking cel and no code. i checked ad rechecked my connections so i got fed up and just clipped the cel wire, its not the best thing to do but every now and then i just check my ecu.</TD></TR></TABLE>
isint that alittle extrame
Old Feb 17, 2006 | 11:50 PM
tpod's Avatar
Default Re: (DieMaster)
it came back, exteremly cold day in the midwest today, when i turned the car on it went on and kept blinking. i hate this cel
Old Mar 1, 2006 | 12:26 AM
Jago's Avatar
Default Re: (tpod)
when the cel flashes that means there is a condition that will damage your catalitic converter
Old Mar 1, 2006 | 05:05 AM
crx_88_si's Avatar
Default Re: (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">when the cel flashes that means there is a condition that will damage your catalitic converter</TD></TR></TABLE>
on a obd-0 car??
tighten your thermostat ground (and clean it up)
Old Mar 1, 2006 | 06:59 AM
tpod's Avatar
thanks for the replies
im going to try it tonight
Old Mar 1, 2006 | 08:54 AM
rbjeepthing's Avatar
Default Re: (Jago)
x2
Old Mar 1, 2006 | 10:31 AM
crx_88_si's Avatar
Default Re: (rbjeepthing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbjeepthing &raquo;</TD></TR><TR><TD CLASS="quote">
x2</TD></TR></TABLE>
i thought this was for obd-2+ only?? never heard of this for a crx on obd-0
Old Mar 1, 2006 | 12:41 PM
tpod's Avatar
im going to check the grounds tommarow
patpeery
Apr 4, 2008 02:40 PM
kaoss_11
Sep 10, 2006 04:14 PM
ph0shizzle
May 13, 2006 08:36 PM
tegon-gsr
Jul 25, 2003 08:26 AM
E-AT_me
Jul 15, 2002 08:43 PM
