P28 ECU
Alright I have this Del Sol that is throwing cel codes 19 and 41. Im kinda under the impression that I have an automatic transmission ECU. Code 19 is Automatic Transmission lock up control valve, and code 41 is primary oxygen snesor heater.But i might be reading the second code wrong but it could be 31, i kinda remember hearing that there is supposed to be an extra flash in between codes. Is there anyway to convert this ecu to a manual without switching Ecus? Any info would be great. Does someone have a link to a complete PIN out for this ECU. I have some extra wires hanging from it and am curious as to where they are supposed to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevinarich »</TD></TR><TR><TD CLASS="quote">Alright I have this Del Sol that is throwing cel codes 19 and 41. Im kinda under the impression that I have an automatic transmission ECU. Code 19 is Automatic Transmission lock up control valve, and code 41 is primary oxygen snesor heater.But i might be reading the second code wrong but it could be 31, i kinda remember hearing that there is supposed to be an extra flash in between codes. Is there anyway to convert this ecu to a manual without switching Ecus? Any info would be great. Does someone have a link to a complete PIN out for this ECU. I have some extra wires hanging from it and am curious as to where they are supposed to go. </TD></TR></TABLE>
Yes, very easy to convert. Go browse http://www.pgmfi.org for more info!
Brewer
Jul 7, 2004 01:49 PM
