Valves
Old Feb 14, 2006 | 06:16 PM
myblackbetty's Avatar
Default Valves
Can valves be adjusted on 1994 Honda Accord 2.2 Liter?
Old Feb 14, 2006 | 06:18 PM
YeuEmMaiMai's Avatar
Default Re: Valves (myblackbetty)
yes and it will cost you about $90 at the dealer. I would also recommend replacing the valve cover and tube gaskets at the time the valves are adjusted so you don't have any oil leaks.
Old Feb 14, 2006 | 06:26 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Valves (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">yes and it will cost you about $90 at the dealer. I would also recommend replacing the valve cover and tube gaskets at the time the valves are adjusted so you don't have any oil leaks.</TD></TR></TABLE>
don't forget the grommets.
Old Feb 14, 2006 | 06:27 PM
Default Re: Valves (MooGoCow3)
aren't the grommets the tube seals?
Old Feb 14, 2006 | 07:14 PM
P_Adams's Avatar
Grommets under hold-down nuts (valve cover center) (#15) (4 Req)
http://www.hondaautomotivepart...COVER
P
user 98292739
Apr 17, 2005 08:22 PM
deconstruct
23
Jun 29, 2004 09:31 AM
alias 33
Apr 16, 2004 11:57 AM
NomacGSR
Aug 1, 2003 05:19 AM
Durante
Apr 17, 2003 03:31 PM
