Washer fluid on the ground
Old Mar 26, 2002 | 10:42 PM
blazed's Avatar
Default Washer fluid on the ground
I gotta 2001 Lude (electron blue)....the dang ole' windshield washer fluid runs out the bottom (front) of the car when I spray it on the windows. Some fluid squirts on the window, but quite a bit leaks out the bottom somehow. Anyone else have this prob.? I'm sure I'll have to take off the front driver-side wheel and peel back the wheel well to fix the problem. I'm thinking there is prolly a hose coming from the resevoir and thats prolly where its leaking. Anyhow, I just wanted to see if any one else had this problem.
cya
Old Mar 27, 2002 | 07:02 AM
kevie88's Avatar
Default Re: Washer fluid on the ground (blazed)
Take a look at the lines while you have a buddy run the washer pump. there is a leak in one of the lines.
david420
Sep 9, 2010 06:48 PM
projekt90ef
14
Apr 19, 2010 09:01 PM
HanSnobbler
Jul 22, 2005 08:14 PM
oscar_lopez03
Jan 20, 2005 08:48 AM
scrubachu
Feb 12, 2002 08:24 PM
