Realy long to warm up
Old Feb 14, 2006 | 05:07 PM
Lewy. Dee Ayy's Avatar
Default Realy long to warm up
Hi, i was wondering if anyone knos why..or if anyone else has the same problem and its just normal for a 95 civic cx to take almost 20 min's to fully warm up. I dont think its my radiator because i have blazing heat.
P.S. same weather..gf's car will warm up in 2 min at the most..(97 CL) and my car will take 20 mins
thanks
fish
Old Feb 14, 2006 | 05:12 PM
NaIsGay's Avatar
Default Re: Realy long to warm up (tqbeastcx)
check the thermostat.. could be stuck open so you have constant flow threw the motor
Old Feb 14, 2006 | 05:16 PM
Heylookits shawn's Avatar
Default Re: Realy long to warm up (CustomX)
yep, 9 times out of 10 long warm ups are caused by a stuck thermostat
cisurfer1's Avatar
def go there fist, my other car didnt have one in it so it took like 15 minutes to warm up in the cold
Old Feb 14, 2006 | 05:17 PM
ham's Avatar
ham
i have the same problem. i changed the thermostat and it did nothing. the old one wasnt stuck. it doesnt make sense to me, just takes at least 15min to get decent heat.
Old Feb 14, 2006 | 05:23 PM
Default Re: Realy long to warm up (ham)
thank god im not the only 1... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem. i changed the thermostat and it did nothing. the old one wasnt stuck. it doesnt make sense to me, just takes at least 15min to get decent heat.</TD></TR></TABLE>
Old Feb 14, 2006 | 05:34 PM
schardbody's Avatar
me and a couple of my EG buddies have the same problems, idling it takes forever to warm up (or the gauge to show it), but if you let it idle for a couple minutes then take off it goes right up. i think its just a common problem with the EGs, maybe the Coolant temp sensors arent sensative or something.
Old Feb 14, 2006 | 05:55 PM
Hybrid96EK's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">me and a couple of my EG buddies have the same problems, idling it takes forever to warm up (or the gauge to show it), but if you let it idle for a couple minutes then take off it goes right up. i think its just a common problem with the EGs, maybe the Coolant temp sensors arent sensative or something.</TD></TR></TABLE>
There is nothing common about that. fix the problem.
Old Feb 14, 2006 | 05:56 PM
ham's Avatar
ham
no its not that, my car is freezing cold til i pull in the parking lot at my work 10+ miles away. i think tqbeast has the same problem.
my friend has the same exact car and it warms up in like 2 miles.
Old Feb 14, 2006 | 06:01 PM
Default Re: (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">no its not that, my car is freezing cold til i pull in the parking lot at my work 10+ miles away. i think tqbeast has the same problem.
my friend has the same exact car and it warms up in like 2 miles.</TD></TR></TABLE>
yup....it sucks..so very much
Old Feb 14, 2006 | 06:06 PM
VALET dude's Avatar
Default Re: (tqbeastcx)
all i can think of is that, if your thermostat is not stuck then maybe you have a very thick oil in the motor. try changing your oil to 5W30 or 10W30. thats just a suggestion tho/what i think.
Old Feb 14, 2006 | 06:07 PM
Hybrid96EK's Avatar
Default Re: (VALET dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VALET dude &raquo;</TD></TR><TR><TD CLASS="quote">all i can think of is that, if your thermostat is not stuck then maybe you have a very thick oil in the motor. try changing your oil to 5W30 or 10W30. thats just a suggestion tho/what i think. </TD></TR></TABLE>
Explain how running a thicker oil would cause the car to warm up slower, please..
Old Feb 14, 2006 | 06:09 PM
ham's Avatar
ham
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">Explain how running a thicker oil would cause the car to warm up slower, please.. </TD></TR></TABLE>
yes, i would also like to know
maybe if i flush out my transmission and use synchromesh, that will help?
Old Feb 14, 2006 | 06:10 PM
ek_chris's Avatar
that problem is not common.
check the thermostat. It's a $5 replacement with the gasket
Old Feb 14, 2006 | 06:21 PM
i use 5W30 <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VALET dude &raquo;</TD></TR><TR><TD CLASS="quote">all i can think of is that, if your thermostat is not stuck then maybe you have a very thick oil in the motor. try changing your oil to 5W30 or 10W30. thats just a suggestion tho/what i think. </TD></TR></TABLE>
Old Feb 14, 2006 | 06:49 PM
schardbody's Avatar
im not saying "long warm up" is common, because mine doesnt take long to warm up even in 32° weather, it just doesnt read warm until i take off/start driving, like the CTS isnt working right. same thing with atleast two other buddies cars.
Old Feb 14, 2006 | 06:50 PM
schardbody's Avatar
the original poster said he has "blazing heat" which means his car is warming up, probably the same problem i got with the gauge just not reading right.
Top-Fuel's Avatar
Honestly I had the same problem but changed my oil and not sure if it was me or I'm just a huge stoner but it warmed up my car twice as fast! no joke try it out
Oh forgot to add what I used: used 10W30!
Old Feb 14, 2006 | 06:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">the original poster said he has "blazing heat" which means his car is warming up, probably the same problem i got with the gauge just not reading right.</TD></TR></TABLE>
once my car is warm..i have blazing heat..so i kno its not the radiator thats making it warm up slow
Old Feb 15, 2006 | 03:05 PM
schardbody's Avatar
ok, i thought you meant you had heat before the gauge read warm, like mine.
Old Feb 15, 2006 | 03:12 PM
aquabob89's Avatar
* B A N N E D *
how long does it take for you cars to cool down?
Old Feb 15, 2006 | 06:16 PM
ham's Avatar
ham
Default Re: (aquabob89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aquabob89 &raquo;</TD></TR><TR><TD CLASS="quote">how long does it take for you cars to cool down?</TD></TR></TABLE>
my car cools down in like 10 min. seriously faster than it takes to warm up. what about you tqbeast?
Old Feb 15, 2006 | 07:00 PM
Default Re: (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">my car cools down in like 10 min. seriously faster than it takes to warm up. what about you tqbeast?</TD></TR></TABLE>
ya cools down quick
Old Feb 16, 2006 | 04:39 AM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tqbeastcx &raquo;</TD></TR><TR><TD CLASS="quote">
ya cools down quick</TD></TR></TABLE>
i honestly think i have a headgasket problem. can you smell burning coolant sometimes?
Old Feb 16, 2006 | 06:15 AM
madlion's Avatar
Default Re: (ham)
i have this problem.. i hooked my vafc up so i know its accurate.. it takes atleast 5-10 minutes to warm my car up on a cold day. i think its the ecu now that ive checked everything else. car idles at like 1400rpm and works its way down. i never leave until its under 1000.. but eventually itll idle at 650-800 depending on the day.. motor is freshly rebuilt.. had this same problem before i rebuilt the engine.. the only thing is that the crankshafts has been polished balaned and lightened everything else is stock.. stock sleeves pistons etc.. i think its an ecu issue
i have obd2 v2 00si..
