Camber Help
Old Feb 14, 2006 | 01:30 PM
Shake and Bake's Avatar
Default Camber Help
The shop that is putting in my omni full coilovers says that they cant put in my cambers also because they dont do alignment. Does any body know any car shops that install and align cambers?
Old Feb 14, 2006 | 01:47 PM
MikeD718's Avatar
Default Re: Camber Help (AllstockSIke)
almost any shop that sells and installs tires/wheels could help you out there.
Old Feb 14, 2006 | 01:50 PM
so, like a pepboys
Old Feb 14, 2006 | 01:52 PM
MikeD718's Avatar
Default Re: (AllstockSIke)
yes, pepboys does alignment.
Old Feb 14, 2006 | 02:03 PM
bmoua's Avatar
well some pepboys dont do alignments for lowered cars....i took mine to a local pepboys and they couldn't do it..damn bastards...but i've heard plenty of people get alignments from pepboys...who have dropped cars...so really just depends on the people i guess...
Old Feb 14, 2006 | 02:13 PM
I thought they might do the alignment but i didnt know that they would install cambers.
Old Feb 14, 2006 | 02:29 PM
schardbody's Avatar
camber is a measurment not an item so you cant install them, you can get camber kits installed. camber kits are a must if you want to keep the treadlife of your tires optimal. im a brake/alignment technician for a living and my car sports eibach sportlines and no camber kits in the front got the good ol bolt and washer combo in the rear, i have virtually no uneven tire wear.
Old Feb 14, 2006 | 02:35 PM
bmoua's Avatar
i have the skunk2 cambers and haven't done the washer trick on the rear but my front tires have good even wear too...when i first dropped my car i dumped it...put on my cambers at the same time but i was stupid and didn't get a alignment untill 1 month later...haha..damn tires wore out quick...took about a good 1000 miles or so though..
Old Feb 14, 2006 | 02:37 PM
JDM-97CX's Avatar
Default Re: (bmoua)
The dealership will do it.
Old Feb 14, 2006 | 02:41 PM
bmoua's Avatar
check out your local phone book bro...from there just find some import shops and call them up and ask if they'll do the installment....easy as that..
Old Feb 21, 2006 | 10:52 AM
Ryan111987's Avatar
go to a small shop it will be a lot cheaper
Old Feb 21, 2006 | 11:04 AM
Filliam H. Muffman's Avatar
Default Re: (Ryan111987)
if u wanna save money, install it yourself, and eyeball the camber. then drive it to a shop to get camber correction.
rrodriguez
Honda CR-V & Element
Jul 31, 2018 05:37 PM
2n-chilli
Suspension & Brakes
Apr 14, 2011 06:24 PM
BoosterSH
Oct 6, 2003 04:03 PM
exr_pd
Aug 4, 2003 08:50 PM
Rust
Apr 24, 2003 12:06 PM
