squealing when I turn the wheel.
I have this annoying squeal that bugs the crap out of me. I hear this noise even when I am parked and my foot is off the brake. the fast I turn the wheel the fast the squeal. Slower vise versa. It also does it when I drive I can hear it sometimes. Anyonehave any idea's on this? Thanks.
Belts, plastic hitting, squeaky tires.
Check all around for anything that's obstructed.
Sometimes the belts will make more noise when turning the wheel also.
I will check the power steering but as for the tires......NO. They are not on backwards and I think I would of known within the first few days they were on. They have been on now for about 4 months. The sound is sounding more like a tie rod or sway bar. BUt not like I would know what they go to or connect to.
I know Ford products have a habit of a tie rod end or ball joint going dry and squeaking whenever the steering is moving, but I've never heard it on a Honda product. Could it be coming from the steering wheel/column? Or can you only hear it coming from the outside of the car? Like stated earlier, it may be your power steering belt coming loose or damaged if the noise is coming from the engine compartment.
mrmonk
Nov 17, 2003 10:29 AM
