Where can i find sleeves?
Old Feb 14, 2006 | 08:08 AM
H22Luda720's Avatar
Default Where can i find sleeves?
I have read the "Mahle Pistons thread" and the "FRM with forged pistons thread". i decided that "FRM compatable" pistons are just a band-aid on a bigger problem, i have decided to sleeve my block. Does anyone know where i can get stock iron inserts for my closed deck h22?, i dont want to spend the money for dartons because i have no need for that much of a bullet-proff sleeve. i want to safly run about 10lbs, but do not trust the stock cast piston ringlands. I have a machine shop that will do the sleeve installing for me so i only need the sleeves. but if anyone knows a good deal at a machine shop, i will consider. Any direction is greatly appriciated.
Old Feb 14, 2006 | 08:37 AM
98vtec's Avatar
moderator emeritus
Default Re: Where can i find sleeves? (H22Luda720)
it helps to do a little bit of searching
golden eagle
benson
darton
Import Builders
to name a few.....
Old Feb 14, 2006 | 08:59 AM
H22Luda720's Avatar
Default Re: Where can i find sleeves? (98vtec)
thats what i'v been doin, all i can find is "Send your block here" deals, i cant find just sleeves
Old Feb 14, 2006 | 09:00 AM
Eddiebx's Avatar
any local machine shop should be able to get you replacement liners, like LA or clevites
90CB7EX
Oct 22, 2016 12:33 AM
93delsolJDM
Feb 13, 2011 11:25 PM
dj-t
Feb 8, 2009 10:47 PM
lasthope05
May 19, 2006 09:03 AM
v4lu3s
Apr 18, 2006 12:48 PM
