[B]I NEED HELP I HAVE A EF8 SIR FRONT CLIP CONVERTION WHAT MOUNTS DO I NEED TO USE TO DO A BERIES SW
Old Feb 14, 2006 | 08:02 AM
jdmrhdcrx's Avatar
Default [B]I NEED HELP I HAVE A EF8 SIR FRONT CLIP CONVERTION WHAT MOUNTS DO I NEED TO USE TO DO A BERIES SW
PLEASE HELP ME OUT I DID A EF8 SIR FRONT CLIP CONVERTION AND I WANT TO KNOW IF I HAVE TO BUY AFTER MARKET MOUNTS OR FACTORY MOUNTS JUST BOLT UP PLEASE HELP ME ASAP
Old Feb 14, 2006 | 08:04 AM
CRX Toad's Avatar
Default Re: [B]I NEED HELP I HAVE A EF8 SIR FRONT CLIP CONVERTION WHAT MOUNTS DO I NEED TO USE TO DO A BERIE
WE NEED MORE DETAIL!!! WHAT MOTOR? WHY ARE YOU FREAKING TYPING IN ALL CAPS!!! STOP IT NOW IF YOU WANT A RESPONSE!
Old Feb 14, 2006 | 08:06 AM
drdisco69's Avatar
Old Feb 14, 2006 | 08:12 AM
jdmrhdcrx's Avatar
well im trying to put a b16 in it or a gsr swap i need to know if i can use same mounts that come with tthe swap or need after market mounts. The swaps are 2000 in year please help sorry for the car peeps
Old Feb 14, 2006 | 08:20 AM
CRX Toad's Avatar
Default Re: (jdmrhdcrx)
Is this a RHD or LHD?
Old Feb 14, 2006 | 08:24 AM
jdmrhdcrx's Avatar
its is a RHD convertion
Old Feb 14, 2006 | 09:31 AM
Smokinsax's Avatar
The Boot
so you are doing an ENTIRE rhd conversion on your car using the whole front clip, or are you just using the the body panels, front bumper, ect. on a USDM CRX?
In the case that you are actually using the EF8 chassis, you will not need any aftermarket mounts to swap in a b series engine. If you are converting your ED chassis with the JDM cosmetics then you will need aftermarket mounts.
Old Feb 14, 2006 | 09:36 AM
SETI20's Avatar
Jesus man...use some damned interpunctuation.
This isn't third grade.
Old Feb 14, 2006 | 10:16 AM
Smokinsax's Avatar
The Boot
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Jesus man...use some damned interpunctuation.
This isn't third grade.</TD></TR></TABLE>
Old Feb 14, 2006 | 11:34 AM
jdmrhdcrx's Avatar
i did a entire front clip not just sheel metel please help
Old Feb 15, 2006 | 04:23 AM
SETI20's Avatar
http://www.speedshoponline.com
Old Feb 15, 2006 | 04:37 AM
bmaca455's Avatar
LOL. If your buying an entire SiR front clip then its obviosly gonna come with a B16 in it to begin with. There would be no need to buy aftermarket mounts seeing as how it was made to hold a B series from the factory.
Old Feb 15, 2006 | 08:36 AM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmrhdcrx &raquo;</TD></TR><TR><TD CLASS="quote">i did a entire front clip not just sheel metel please help </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">In the case that you are actually using the EF8 chassis, you will not need any aftermarket mounts to swap in a b series engine.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmaca455 &raquo;</TD></TR><TR><TD CLASS="quote">LOL. If your buying an entire SiR front clip then its obviosly gonna come with a B16 in it to begin with. There would be no need to buy aftermarket mounts seeing as how it was made to hold a B series from the factory. </TD></TR></TABLE>
italianboy894
Dec 2, 2007 09:37 PM
FutureCivic
Jan 29, 2007 04:25 PM
B!^A@
Oct 3, 2006 08:21 PM
jdmrhdcrx
Feb 14, 2006 09:11 PM
