ok so last night my car back fires and dies on me...
Old Feb 14, 2006 | 05:02 AM
TehMan's Avatar
Default ok so last night my car back fires and dies on me...
and it starts to smell like gas really bad...so i take the msd dizzy cap off and find the pos. wire running to the blaster 2 coil loose...so i fix it and put the cap back on...then i try to start my car and it turns over but won't start...then when i turn the key off...after about 2 seconds, air shoots out of my TB and it sounds like a blow off valve...lol...so i take the plugs out and they got gas on them. so i let them dry off and then plug in directly into the spark plug wires and touch a ground while my cousin turn over the car...and no spark...what could be wrong with it? its a 95 b18b1
Old Feb 14, 2006 | 05:04 AM
Spectrum24x's Avatar
Default Re: ok so last night my car back fires and dies on me... (AllMotorB18B)
one thing i've learned, always start simple... fuse
When your wire came out on the dizzy it probably shorted a fuse out, run through and check all your fuses... dont forget the ones in the engine bay as well as the drivers side panel.
Old Feb 14, 2006 | 05:09 AM
TehMan's Avatar
Default Re: ok so last night my car back fires and dies on me... (Spectrum24x)
thanks
i'll check that out when i get off of work...i have a friend thats a tech at honda that is going to come try to help me with it tommorrow...i just want to try and get it done tonight lol
Old Feb 14, 2006 | 05:22 AM
Is there any noises when you crank it over? like maybe a ticking? does the CEL flicker?
Old Feb 14, 2006 | 05:27 AM
TehMan's Avatar
no CEL and no tick...it turns over just no spark...i might try putting the internal coil back in and see what happens
Old Feb 14, 2006 | 06:52 AM
Reid's Avatar
Global Moderator
Get rid of the MSD, as it's useless anyway.
Old Feb 14, 2006 | 07:37 AM
TehMan's Avatar
Default Re: ok so last night my car back fires and dies on me... (Reid)
it was free...so i figured why not use it
Old Feb 14, 2006 | 07:40 AM
1337whp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Get rid of the MSD, as it's useless anyway. </TD></TR></TABLE>
Old Feb 14, 2006 | 10:10 AM
TehMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorB18B &raquo;</TD></TR><TR><TD CLASS="quote">it was free...so i figured why not use it</TD></TR></TABLE>
Old Feb 14, 2006 | 10:20 AM
DirtyBirdJR's Avatar
stupid question do the cams still move? timing belt? timing?
Old Feb 14, 2006 | 10:42 AM
TehMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorB18B &raquo;</TD></TR><TR><TD CLASS="quote">it turns over but won't start...</TD></TR></TABLE>
it's not getting spark
Old Feb 14, 2006 | 10:47 AM
CleanLikeJdm's Avatar
Hype-R Stalker
msd == headache
Check spark Directly from the pack,
It probably just went, get a replacement stock coil.
Usually there won't be signs, I had an MSD pack,
and a stock coil die out of nowhere, with no prior signs of wear.
Old Feb 14, 2006 | 11:25 AM
TehMan's Avatar
Default Re: ok so last night my car back fires and dies on me... (FlatBlackTeg)
i put an external coil on it...so there is no internal(stock) coil in it anymore...
Old Feb 14, 2006 | 02:50 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote"> get a replacement stock coil.
what brand would u suggest?
Old Feb 14, 2006 | 04:42 PM
Hype-R Stalker
replacing the Internal coil is really simple, I can probably take pics,
One of a dizzy that had an external and one with an internal,
All you do is plug a wire or two in and thats all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">what brand would u suggest?</TD></TR></TABLE>
The first time mine went I just got a used coilpack,
and then the 2nd time I had an obd2 dizzy,
So I just swapped the pack from that to my old dizzy shell,
But if the coilpack is cheap enough, just buy it from any parts store.
95DC2GS-R
Dec 21, 2008 08:54 PM
PerfectTechs
Mar 23, 2008 10:15 AM
yoursupahero09
10
Jan 23, 2007 04:19 AM
CLE
11
Aug 1, 2006 08:23 PM
pearlintegra
Jul 24, 2003 10:45 AM
