check engine code 6
OK. So i cracked my transmission and finally got around to replacing it with a stock S20 tranny. Everything was swapped over. All the sensors were switched over onto the new tranny. Somehow its throwing a Code 6. I've replaced the water temperature sensor with a stock one from a CX motor and it still throws the same code. I dont know if something is wrong with it because i've already replaced the sensor and it was not part of the tranny swap. The motor is a stock D15B7 motor with a new stock S20 tranny on a 93 civic. let me know if theres a way to remove the check engine light since the sensor cant be the matter. I've tried resetting the ECU already and still throws the same code. Thanks
9WON4
Apr 22, 2004 05:38 PM
