DX TPS pn B16A1 in EG?
Old Mar 26, 2002 | 07:31 PM
D1ANCER's Avatar
Default DX TPS pn B16A1 in EG?
I used mt TPS off of my DX to put on my B16A1 because the one it had was crushed. Will this affect my overall performance? I am also running my stock fuel pump and DX injectors, do I need to upgrade? My engine seems to be deprived of fuel and doesn't want to respond immediately when I mash the gas. I am also running the DX radiator to cool this beast. Is that enough? I don't want it to overheat.
Any help would be greatly appreciated.
Old Mar 27, 2002 | 01:57 AM
b19coupe's Avatar
Default Re: DX TPS pn B16A1 in EG? (D1ANCER)
The TPS should be fine.TPS is just a variable resistor that changes resistance in relation to throttle position,most Honda TPS's are interchangeable. You just need to be sure that it is set properly. You might want to upgrade your fuel delivery system though.
[Modified by b19coupe, 10:58 AM 3/27/2002]
Old Mar 27, 2002 | 06:56 AM
D1ANCER's Avatar
Default Re: DX TPS pn B16A1 in EG? (b19coupe)
What is a good fuel pump? What all should I buy to get better fuel to the engine?
Old Mar 27, 2002 | 07:22 AM
bigblockEG's Avatar
I used the TPS off of a CX on my GS-R and it works fine. However, I would upgrade the fuel system. Depending on mods you may not need injectors, I would look into changing the fuel pump though. I recommend the venom fuel pump. Good bang for your buck. Maybe a FPR too. If you go with one of those go with an AEM. They make descent quality stuff.
ProjectRustyEF
Apr 8, 2008 01:38 PM
Sleek98
Apr 13, 2005 09:59 AM
Ricey McRicerton
10
Sep 27, 2003 03:45 AM
guttedhatch
Jun 10, 2003 10:32 AM
