What Gauges Are These, and Will they work in my hatch?
STD Cluster:
Other Cluster:
My friend gave me these gauges he said he found them at the junk yard but didn't know what they were from.
My STD Gauges are on the right, and the new one is on the left. I'm thinking it came from like a 88-89 4door, but will I be able to get them to work in my 91 STD Hatchback? I hooked them up and all the plugs plugged it and some of the lights worked but I didn't get to put it back together because it got dark.
Will they work?
Modified by deanh8 at 5:18 AM 2/14/2006
Modified by deanh8 at 5:42 AM 2/14/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsinnovation »</TD></TR><TR><TD CLASS="quote">btw i think you just wanna show ur supercharger........</TD></TR></TABLE>
wtf yeah because a bunch of ef guys care about a supercharger thats not even for a honda
I tried searching but I didnt know if it was an LX or Si cluster, and didnt know if it was an 88-89 or a 90-91.
yea its an 88-89 cluster and you can get it to work in your car. i had a 90-91 cluster in a 88 civic. all i had to do was repin the connectors to the 90-91 connector. so u will also need the 88-89 connectors and repin ur 91 wires to em. that makes sense?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb_guy »</TD></TR><TR><TD CLASS="quote">looks like my 91 ex cluster, just put them in and let us know!!</TD></TR></TABLE>
I tried but the holes didnt line up and it wouldnt screw in right. I didnt take the time to make it fit, it got dark outside I will try again tomorrow.
I cant find anything, All the posts I have found with the same problem as me they get told to search. I cant find anything.
Anyone know where I can find out how to rewire a 88-89 cluster to a 90-91 car?
Needs to be About 20% Cooler
take a pic of the idiot lights and ican tell ya what body and year it's from
if the highbeams are in with oil, etc... then 88-89 if up be left turn signal than 90-91. also if it has a cruse cotrol light than it's from an LX or EX sedan. if it had a BIG seatbelt light it's from a hatch. if not than DX sedan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">take a pic of the idiot lights and ican tell ya what body and year it's from
if the highbeams are in with oil, etc... then 88-89 if up be left turn signal than 90-91. also if it has a cruse cotrol light than it's from an LX or EX sedan. if it had a BIG seatbelt light it's from a hatch. if not than DX sedan. </TD></TR></TABLE>
Im guessing its an 88-89 DX Sedan then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX »</TD></TR><TR><TD CLASS="quote">interesting fact.. i thought only the si's had the 6500 redline? where in SJ are you at?</TD></TR></TABLE>
Milpitas most of the time, southside if im not in milpitas.
Modified by deanh8 at 12:53 AM 2/14/2006
Cluster on left is 88-89, on right is 90-91. The top of the 88-89 is flatter than the other and you must use the metal mounting hardware that screws into the cluster or it won't fit when changing between the 2 different years (88-89 to 90-91). You will also have to move some wiring, and swap cluster hoods as stated before. Then the switches in the hoods are different, requiring relocation and more rewiring. If you find you aren't going to use the 88-89 cluster, I might be intrested in taking off your hands. Let me know if you need more help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood »</TD></TR><TR><TD CLASS="quote">Cluster on left is 88-89, on right is 90-91. The top of the 88-89 is flatter than the other and you must use the metal mounting hardware that screws into the cluster or it won't fit when changing between the 2 different years (88-89 to 90-91). You will also have to move some wiring, and swap cluster hoods as stated before. Then the switches in the hoods are different, requiring relocation and more rewiring. If you find you aren't going to use the 88-89 cluster, I might be intrested in taking off your hands. Let me know if you need more help.</TD></TR></TABLE>
So not worth it?
So not worth it?
this guy is correct... its from an 88-89... i put one of those in my 91 but had to do a bunch of rewiring... also there will be a gap in the top if you don't get the 88-89 hood...
i'd say that you should save yourself some trouble and get a 90-91 cluster and be done with it... no rewiring and no gap... i learned the hard way..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsinnovation »</TD></TR><TR><TD CLASS="quote">thats up to you. its worth it if its all you have and you need a tach.</TD></TR></TABLE>
Yeah but I have no idea how to hook it up.
Dean, what you want to do can be done but it takes a lot of work. You will be better off finding a cluster for a 90-91 model. I have been trying to get a working cluster for my 16 year old son and have discovered that there is a lot involved in getting a cluster to work. E-mail me and we can talk. Good luck, Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRedline89Hatch »</TD></TR><TR><TD CLASS="quote">i have a cluster from a 90 crx si. you wanna trade? im lookin for a cluster for my 89.</TD></TR></TABLE>
Got any pics?
Got any pics?
