Questions about DIY BLACKOUT HEADLIGHTS.
Hey guys, I need help with my DIY. When you first take out the headlights and put it in the oven to heat it up, I just havea couple of quesitons.
1. From the picture, are these 3 parts from ONE headlight?
2. When you pry it part after taking it ouf of the oven, do you take 1 apart or 2 apart from 3?
I'm not 100% sure on the RSX headlight, but aside from the usual metal clips along the seam it's just the glue holding it together, so you can pry them apart, by hand, maybe, more likely with a screwdriver, I think. Then the rest should be obvious.
Theres no screws. Its clips. Careful not to break them while prying it apart.
This should help
http://www.members.tripod.com/...8.htm
This should help
1 day. I wouldnt say any given amount of time. You wanna make sure the paint is FULLY dry before you reassemble. I had a day off so i took my time. By the end of the day they were back in the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chizzadd »</TD></TR><TR><TD CLASS="quote">what if i use caliper paint....and make them blue??
would that look tight?</TD></TR></TABLE>
I have seen people do body color matching. That looked good.
hmm im thinking about it....would be cool i think
heres a pic of the caliper paint jus for your knowledge
and it drys fast
prolly wouldnt have to wait freakin 24hrs for it to dry
so if i do it...it will be saturday and i'll post up for sure!
didn't mean to hi-jack your thread gsr009vtec
and it drys fast
