How to take off cluster glass/Or how did you put in your bezel??
Old Feb 13, 2006 | 06:39 PM
A-busive's Avatar
Default How to take off cluster glass/Or how did you put in your bezel??
Hey guys a while back i bought a carbon fiber bezel to put in my cluster, but while i was doing it i broke the glass b/c i didnt know i too take if off. So i saw a auto cluster off ebay and it's almost over so i wanted to buy that cluster for dirty cheap and take the glass off and put it on mine manual cluster. Just wanna know i guess is will the glass fit you think? and how to take off the plastic part carefully?? Or how did you put your bezel in?
Old Feb 13, 2006 | 06:45 PM
instrument's Avatar
hey, i got just the cluster part if you want it, i'll give it to you for like 20 bucks or something if you're interested? i know this isn't the forsale section...but..yeah..he needs it..i dont...its sitting on my desk right next to me..
took a picture
Modified by instrument at 8:22 PM 2/13/2006
Old Feb 13, 2006 | 07:14 PM
A-busive's Avatar
Default Re: (instrument)
i'll take it
Old Feb 13, 2006 | 07:18 PM
sicky's Avatar
grammer nawzi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">hey, i got just the cluster part if you want it, i'll give it to you for like 20 bucks or something if you're interested? i know this isn't the forsale section...but..yeah..he needs it..i dont...its sitting on my desk right next to me..
took a picture
Modified by instrument at 8:09 PM 2/13/2006</TD></TR></TABLE>
Now that's business man. Turning the tech thread into a for sale/sold thread. Nice work. Best of luck getting the thing put together without breaking it.
Old Feb 13, 2006 | 07:22 PM
A-busive's Avatar
Default Re: (sicky)
yeah i know great huh, but how do i put the bezel in w/o breaking it the plastic glued down nicely
Old Feb 13, 2006 | 07:26 PM
instrument's Avatar
hey, we're here to help each other...i'm hoping?
abusive i'll pm you with my info.
Old Feb 13, 2006 | 07:29 PM
A-busive's Avatar
ok,but does neone know how to remove the plastic plz help
Old Feb 13, 2006 | 07:33 PM
zerovandez's Avatar
It should just be platic tabs that you push down and out. I did that with my Si cluster. It's not difficult at all.
Old Feb 13, 2006 | 09:12 PM
WishinItWas's Avatar
Default Re: (zerovandez)
never done it with a EG cluster but i did on on my MX-6 i had in High school, i took a really small regular screwdriver and stuck it in the really small gap between the black and clear plastic, rotated gently so not ot crack the plastic and just went alllllllll the way arround reall slow untill it popped off. sorry no pic how this helps a lil bit
Old Feb 13, 2006 | 10:01 PM
5 Skware's Avatar
I missed the boat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">It should just be platic tabs that you push down and out. I did that with my Si cluster. It's not difficult at all. </TD></TR></TABLE>
Yep takes all of about ten seconds....not hard on the slightest
Old Feb 14, 2006 | 12:22 AM
BlueIntegraBoy's Avatar
The clear plastic piece is glued to the bezel. The only safe way of removing it without breaking the plastic is to heat it up.
Old Feb 14, 2006 | 07:34 PM
A-busive's Avatar
Default Re: (BlueIntegraBoy)
thank you a guy who know what im talking about, but how do i heat it up? will a blow dryer work?
Old Feb 14, 2006 | 08:07 PM
Slewbang's Avatar
Default Re: (aallbbeerrtttttt)
Those who say it's 10 seconds are talking about EK clusters.
I've replaced the "glass" on my EK cluster since mine was good with no tach, I switched for a EX cluster with a crack. Those are easy.
On the EG it's glued on hard, with no push tabs. I had a JDM cluster in my coupe and it came with a scratched glass, so I switched them too.
What you do is use a BOX Cutter. You need a box cutter, because it's the only thing skinny enough to get in there. Slip the blade in between the glass and the cluster, and "cut" the glue beads. Firm yet gentle, this is hard glue, not soft glue. When it breaks, it snaps, so be careful.
This is the cluster when I got it: (deep smudges, scratches)
Switched glass with my coupe:
Old Feb 14, 2006 | 08:16 PM
A-busive's Avatar
Default Re: (Better Than You)
so to put it back on after i put the bezel in do i use glue
Old Feb 14, 2006 | 08:26 PM
Slewbang's Avatar
Default Re: (A-busive)
Yes.
Use superglue, but dont use the tip of the glue applicator on the cluster or glass, or you get frost. Pour the glue on something and use like a pencil tip to spread the glue.
20-EM2-05
Honda Civic (2001 - 2005)
Aug 20, 2009 12:14 PM
3s0n3
Apr 19, 2007 01:08 AM
xxwhixx
16
Apr 5, 2006 08:55 AM
