having a lil trouble with the ebrake cable
ran into the same problem this weekend
its a bitch to remove the cable from the drum assembly
i just mangled the fitting that held it to the drum
took about an hour and a half
i know there has to be an easier way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx »</TD></TR><TR><TD CLASS="quote">ran into the same problem this weekend
i know there has to be an easier way</TD></TR></TABLE>
yeah disconnect the cables inside the car and drop the trailing arm. No need to disconnect the cable from the drum .You wasted an hour and a half LOL
to the op, could you give some more info? What is the problem with the ebrake cable?
It's a tight fit getting the cables unbolted from near the gas tank.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">yeah disconnect the cables inside the car and drop the trailing arm. No need to disconnect the cable from the drum .You wasted an hour and a half LOL</TD></TR></TABLE>
^ haha sad but true
^ haha sad but true
