Basically NEW Turbo Kit for H22 (IC piping may only work for 94-97 accord)
Old Feb 13, 2006 | 04:49 PM
2000Accord5sp's Avatar
Default Basically NEW Turbo Kit for H22 (IC piping may only work for 94-97 accord)
Up for sale is a full turbo kit for h22 in an 5th gen accord for $2500 (including full 3" exhaust and dump pipe)
These parts were hooked up to the car and car idled but never even boosted. Basically just been sitting on the car but never used!
What you get:
New Red Tial 40mm Wastegate, .8 bar
New Red 46mm Blow Off Valve, 18" spring
New South Florida Performance Turbo Manifold ceramic coated (helps greatly reduce underhood temps) - not one those log style cheap manifolds
Brand new T04E/T3 hybrid Turbo, 50 trim CW, stg III TW, .63 A/R TH (capable of over 400+ hp)
Oil lines and fittings for both oil feed and oil drain lines (drain fittings are scratched up some because of the tight space when installing)
Custom built intercooler pipes (comes with mounting plates already installed for wastegate and BOV) and powder coated glossy silver - looks great!
New Griffin 40" x 12" x 2.75" HUGE front mount intercooler
Custom built downpipe - flares out to 3"
Custom built Wastegate dump pipe
Custom built full 3" exhaust with dual tip Magnaflow muffler and silencer built in - also with quick release mechanism for disconnecting exhaust at races and you won't have to replace the exhaust gasket!
Try and peice these together for under $2500 new. I've paid a lot more for all these parts put together and never even got to use them.
Exhaust - This exhaust is CLEAN and very good flow. Won't knock your head out with the silencer on it as well
Note the picture with the connector, with this, you can disconnect from the dump pipe the whole exhaust for the race track and not have to replace the gasket. This will seal it compeltely when you clamp the pipes together!
Turbo - This turbo is HUGE
T-fittings used - not those cheap ones, these cost $8 each!
IC and IC Piping
Old Feb 14, 2006 | 08:25 AM
Default Re: Basically NEW Turbo Kit for H22 (2000Accord5sp)
bump
Old Feb 15, 2006 | 07:47 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
if your parting out how much for the charge piping.
Old Feb 15, 2006 | 09:20 AM
replied to your PM. Anyone else who wants parts, feel free to let me know.
Old Feb 19, 2006 | 02:23 PM
kamAccord's Avatar
How much for turbo manifold , downpipe, dump tube and intercooler piping? Possibly wastegate and blowoff valve. If so, how much? Does the manifold have a T3 flange?
bustedb16a
Apr 21, 2008 07:37 PM
6thgenaccord
Mar 29, 2007 06:50 PM
2000Accord5sp
Northwest (Sales)
Apr 6, 2006 07:36 PM
JdmH22Acorn
Nov 16, 2005 07:52 AM
sir3n
Mar 10, 2004 08:27 PM
