LS Turbo ??? OR LS VTEC Turbo????
Alright....... Me and my Co-worker are having this debate about this topic. I say that turbo'ing the LS would be just as good as turbo'ing it LS Vtec. I mean the money he would have to spend on converting the LS into Vtec is just retarded in my opinion if you could just go and through a turbo on it. How much more power could you gain by putting Vtec turbo on a LS. So holla back with what you peeps think.
Just Boost an Ls. LS/V is going to cost you more in the long run to do it right and won't put out as much power or be as reliable. Just put that money, and build up the LS. If you stay around 10psi and tune right you can just run stock internals no problem.
Try searching there is alot of info on this site. http://www.team-integra.com is a great place w/ a lot of info also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegG2 »</TD></TR><TR><TD CLASS="quote">Just Boost an Ls. LS/V is going to cost you more in the long run to do it right and won't put out as much power or be as reliable. Just put that money, and build up the LS. If you stay around 10psi and tune right you can just run stock internals no problem.
Try searching there is alot of info on this site. http://www.team-integra.com is a great place w/ a lot of info also. </TD></TR></TABLE>
what he said
