4th gen corner removal
Old Feb 13, 2006 | 03:41 PM
preludese111's Avatar
Default 4th gen corner removal
I'm replacing my corner lenses. Do I need to take the bumper off or just take out the phillips screw and pull it forward? Thanks.
Old Feb 13, 2006 | 03:46 PM
94Vtecluder's Avatar
Default Re: 4th gen corner removal (preludese111)
No each corner lens has philips head screw on top. Just unscrew it, unhook the bulb and pull the lens out. Unless you have JDM headlights....
Old Feb 13, 2006 | 03:48 PM
Default Re: 4th gen corner removal (94Vtecluder)
How do I unhook the bulb. Where can I get to it from?
Old Feb 13, 2006 | 04:29 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Unscrew the phillips screw, GENTLY pull directly out on the corner lamp, then remove the socket/harness whatever you want to call it.
Old Feb 13, 2006 | 05:27 PM
Default Re: 4th gen corner removal (Chief Brody)
I unscrewed the screw, disconnected the harness via the wheel well and it is still attached to something next to the headlights. I've only tried the driver side so far though, so maybe the passenger one will come out easier. I'll have to do it tomorrow though, I'm a little flustered. Thanks for the help guys.
Old Feb 13, 2006 | 06:04 PM
Jos3ph's Avatar
just made it. hope this helps.
the corner lense is pretty tough to pry out. it will require quite a bit of pressure but it will come out.
Modified by Jos3ph at 10:36 PM 2/13/2006
Old Feb 13, 2006 | 06:18 PM
Partizan's Avatar
no you dont need to take off the bumper
Old Feb 13, 2006 | 06:27 PM
Community Builder
Default Re: (Partizan)
Mine were really hard to get out. Just pull like hell, but be careful at the same time.
Old Feb 13, 2006 | 06:30 PM
Default Re: 4th gen corner removal (Jos3ph)
Thanks a lot. That diagram really helps a lot! Thanks for the help guys.
dyalnowalker
Jun 15, 2007 09:59 PM
92piece
Jun 16, 2006 11:45 AM
l2yanE
Jan 31, 2006 08:28 PM
jakej
Feb 3, 2003 06:34 PM
