Stupid Nweb questions
Newb here can't really seam to find too much stuff on my car. I have a 1998 accord V6 and i am looking for some wheels and maybe some performance stuff, anyone recomend some good vendors? this site seams to be geared more twords civics,tegs,and ludes. Also where is the OBDII port on my car? thank you
you can check http://www.andysautosport.com for performance parts. if i were you id go with suspension mods first. this site has plenty of information on accords. your best tip is to search before you post. it will save you from alot of flaming.
My advise is to get yourself a service (repair) manual for your car. Helm is the factory repair manual (about $70 +$30 or so for V6 supplement) or you can go the cheap rout, and get one from Autozone or Advance. The OBDII port is under the dash, near the hood release.
http://www.helminc.com/helm/Re...RASGE
They would be the last two on the list. If you're interested.
another site you might want to look at is http://www.v6performance.net but there is alot of rice on that forum
save your cash for a stronger transmission.
There isn't too much you can do to the 3.0L to get many more ponies without dropping at least a grand on I/H/E.
A better bet would be to use the 3.5L block with the Av6 heads that would get you about 265HP. You can use the odessey block or one from a Acura MDX (03 or earlier)
Read thhe FAQ 6th gen thread to get information on how to get codes and what they mean.
ok well i ran some codes and it looks like i got a 1739 (manufactuar control trans, don't know what that means), 300 mult cylnder missfire, 305 and 301 cylnder 5 and 1 missfire
Anyone know what to make of these? should i just change my spark plugs to get rid of the missfire codes? are they common on this motor? thanks
Arocha
18
Nov 18, 2011 03:49 AM
CivicSD
11
May 25, 2010 04:36 PM
fishsticks37
Apr 4, 2004 07:04 AM
