Drag turbo kit, 460cc injectors
Drag Turbo kit Gen 3 for b series in EG or for integra......had the kit on a bone stock b16a2 @ 7psi and it made 240hp and 170 ft. lbs of torque at the wheels. Only used the kit for 4 months, practically new. $1800 USD
Kits come complete with the following:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 High flow turbocharger assembly
Turbonetics Deltagate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/
polished cast aluminum end tanks
BLITZ Super Blow Off Valve
Drag mandrel bent high flow chrome plated intercooler pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegaste dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass valves
Stainless steeloil feed line w/ fittings
Oil return line w/ fittings
All nessasary hardware and fittings
All nessassary hose and hose clamps
All nessassary gaskets
Extra: honda injectors done to flow 460cc......$180
Located in Toronto,Ontario.. Canada
Tinberland21
Apr 6, 2008 06:19 PM
