rear subframe rusted out
Old Feb 13, 2006 | 02:38 PM
shadycrx's Avatar
Default rear subframe rusted out
ok so i took the car into the shop today to see what was wrong with the front suspension and turns out my rear subframe (the one with the steering rack) is completely rusted out and the sway bar mount on the passenger side is just dangling in the air and there's a big hole where it used to sit, my question is since i might not be able to get a new subframe soon would it be okay to just take out the front sway bar for the time being? because the way it is right now it makes the car very unstable and pull to the right randomly. any suggestions...this is a very mild daily driven hf so would i be okay without a front sway bar for a while or not?
Old Feb 13, 2006 | 02:52 PM
Tyson's Avatar
Default Re: rear subframe rusted out (shadycrx)
um yeah, that will cause some thumping sounds....
it will be totally fine if you take off the swaybar.
Old Feb 13, 2006 | 02:58 PM
ludesrv's Avatar
Just go to the wreckers and get a new one. I picked one up for 50$ and got the seal on it replaced, then I swapped it with my rusted out one.
Old Feb 13, 2006 | 03:01 PM
shadycrx's Avatar
Default Re: (ludesrv)
what seal ?
update:: took off the sway bar, problem solved i think
Modified by shadycrx at 7:32 PM 2/13/2006
dayaftertomorrow33
Acura TL, RL & ZDX
Apr 24, 2016 08:51 PM
zippo1130
15
Jan 15, 2008 07:45 PM
chrisw85
Suspension & Brakes
Oct 24, 2006 01:02 PM
STHPERFORMANCE
Oct 4, 2002 11:05 AM
