code 8
Old Feb 13, 2006 | 01:47 PM
JinksItR's Avatar
Default code 8
what code is it???
Old Feb 13, 2006 | 02:16 PM
31flavorscivic's Avatar
Default Re: code 8 (JinksItR)
https://honda-tech.com/zerothread?id=468260
Old Feb 13, 2006 | 02:24 PM
RCautoworks's Avatar
Default Re: code 8 (31flavorscivic)
Code 8 - Top Dead Center Sensor
It's the second sensor in the dist. It can also be located on the camshaft of DOHC engines. It determines the injection timming for each cylinder, also used to detect engine speed (rpm) to read the basic discharge duration, for different operating conditions.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up, to a 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
jdm206
Apr 28, 2007 12:18 PM
2poor2tune
Jun 23, 2006 01:38 PM
Tippyman
Mar 10, 2006 06:03 PM
jccrxtuner916
Feb 12, 2006 10:32 PM
1991dxhatch
Apr 8, 2004 04:59 PM
