e timeneed help w/ fuel problem
Old Feb 13, 2006 | 01:44 PM
89sicivic's Avatar
Default need help w/ fuel problem
well i just replaced the fuel pump in my 89 si...and it worked just fine clicked on most of the time but sometimes it doesnt..so i made sure the wires outside the car that go to fuel pump were still connected and they looked loose and might have touched each other my question is if this happend would it blow any fuses and if so where those fuses are or did it short out the fuel pump...need help fast..
Old Feb 13, 2006 | 02:35 PM
Perfectionist's Avatar
Default Re: need help w/ fuel problem (89sicivic)
Clicked on most of the time? Should 'click on' all the time. Did you R/R the main relay?
If the wires touched, yes, you could have blown a fuse, but the circuit would be dead all of the time if that was the the case. And no, the pump would not have shorted out in that case.
Old Feb 13, 2006 | 03:05 PM
89sicivic's Avatar
i know it should click on all the time what you mean by r/r the main relay?....i just recently went out and tried it again it clicks on everyonce in a while and then starts up...
Old Feb 13, 2006 | 04:23 PM
Default Re: (89sicivic)
repair/replace the main relay. Do a search for the subject. It's a common cause for no fuel pump activity.
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
snzh22
Aug 8, 2007 04:53 PM
skoolz4loserz
11
May 10, 2006 08:52 AM
EF9ZC
Apr 3, 2006 08:36 AM
