Switching to OBD1 (Hondata?)
Old Feb 13, 2006 | 01:01 PM
jvonb's Avatar
Default Switching to OBD1 (Hondata?)
I have to switch to OBD1 because the ECU that i have now is not the right one for my motor (B18c1) i think my ECU is OBD0. One of my choice is to get the custom ECU, ECU adapter, and dizzy adapter off locashracing.com. Another option would be to get a used OBD1 ECU from a junk yard and getting a hondata system that way I could program it how i wanted. What does everyone think i should do and what wold be the best choice.
Old Feb 13, 2006 | 03:53 PM
da6jdmteg's Avatar
Default Re: Switching to OBD1 (jvonb)
is your car obd-0 or obd-1?
Old Feb 13, 2006 | 04:57 PM
jvonb's Avatar
Default Re: Switching to OBD1 (da6jdmteg)
it is OBD0 but i have a B18c1 motor so it needs to be ODB1. It runs but does not idle good and stalls alot.
Old Feb 14, 2006 | 03:32 PM
jvonb's Avatar
bumb need some opinions
Old Feb 14, 2006 | 06:03 PM
fliptout's Avatar
So are you running a Vtec Motor with a non vtec ECU? What was your car to begin with? did you have Vtec originally? If your car was not Vtec to start: Did you run the wires for the knock sensor? If you run the P72 you need to run additional wires. It just depends on what all you have.
SrbijaDoTokija
Jul 6, 2017 07:36 AM
RyceRacerX
Dec 8, 2009 07:41 AM
ViperRedCRX
11
May 20, 2003 10:54 AM
