Pics of my new ITB manifold -- built by me
Old Feb 13, 2006 | 11:58 AM
Rosko's Avatar
Default Pics of my new ITB manifold -- built by me
hey just posted this up in the prelude forum since thats what its for but i thought some of you other machinist might want to check it out and give me some feedback.
thanks-shawn
https://honda-tech.com/zerothread?id=1526349
Old Feb 13, 2006 | 01:33 PM
jon volk's Avatar
Default Re: Pics of my new ITB manifold -- built by me (Rosko)
Badass
Old Feb 13, 2006 | 01:37 PM
EJ1 wilcox's Avatar
Default Re: Pics of my new ITB manifold -- built by me (k20 jon)
WoW
I didn't think it had throttle plates at first because of the way you have built them. They look very clean and simple. Excellent work!
Old Feb 13, 2006 | 11:37 PM
Rosko's Avatar
Default Re: Pics of my new ITB manifold -- built by me (EJ1 wilcox)
thanks guys! yeah i got 2 springs tucked away in there too on each side of the throttle arm.
Old Feb 14, 2006 | 11:25 AM
lohatch's Avatar
wow great work
Old Feb 14, 2006 | 05:29 PM
: alexander :'s Avatar
Default Re: Pics of my new ITB manifold -- built by me (lohatch)
damn nice work - ask TWM for a job and then make roller style openings for the next batch
Old Feb 14, 2006 | 09:30 PM
Tony the Tiger's Avatar
That is some awesome fabrication right there
Old Feb 15, 2006 | 12:01 AM
PolyPill's Avatar
Default Re: Pics of my new ITB manifold -- built by me (Tony the Tiger)
Did you make the butterfly plate too or did you buy them? I just thought it would be difficult to size it exactly right. Also where did you get the air tight bearings?
That's some tight work
Old Feb 15, 2006 | 02:53 AM
Rosko's Avatar
Default Re: Pics of my new ITB manifold -- built by me (PolyPill)
the blades are very easy to make. im running about a .001 per side clearance and im using bronze bushings instead of bearings. yeah they will leak a little but not enough to matter. i should be able to close it up tight enough to kill the motor if i wanted to.
when i build single tb's i do use bearings and then a seal similiar to an oil seal on the outside of the bearing. the tps end is still a bushing but the tps sensor itself uses a gasket so that traps the remaing air.
since this manifold doesnt use idle air control the butterflies will have to be cracked open a bit just to get it to idle so any air that would leak through the bushing isnt gonna hurt anything.
9295EJ-t
Welding / Fabrication
49
Jan 16, 2010 08:17 AM
fernancivic
Aug 5, 2009 01:03 AM
Rosko
Mar 25, 2007 03:58 PM
AntiStock
Dec 15, 2005 05:59 PM
u_tal
Dec 13, 2004 05:52 PM
