Pics of my new ITB manifold -- built by me
Old Feb 13, 2006 | 11:43 AM
Rosko's Avatar
Default Pics of my new ITB manifold -- built by me
ok so i finally took some pics of this thing for you all to see. i designed and built this all myself. let me know what you think.
Old Feb 13, 2006 | 11:46 AM
mrOswaldIII
Guest
Posts: n/a
Default Re: Pics of my new ITB manifold -- built by me (Rosko)
I'd say they look pretty clean How much time and money do you have invested into this? and when will you have them on a car? thanks
Old Feb 13, 2006 | 11:51 AM
ThE PiMpiN Co's Avatar
Default Re: Pics of my new ITB manifold -- built by me (mrOswaldIII)
Props
Old Feb 13, 2006 | 11:55 AM
Rosko's Avatar
probably about 50 hrs of machine time and tons more design time. this is actually the 5th manifold i've done, they've all been different but if you fiure all that design and developement time it really adds up.
i made this before i quit my last job so the material was "donated" and all it really cost was my time.
Old Feb 13, 2006 | 12:03 PM
syntax.'s Avatar
damn, they look nice. props for the custom work. gotta love "donated" material down with the man!
How do you plan on tuning them? i dont see anywhere to mount a tps. . .
Old Feb 13, 2006 | 12:11 PM
Rosko's Avatar
Default Re: Pics of my new ITB manifold -- built by me (syntax420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 &raquo;</TD></TR><TR><TD CLASS="quote">damn, they look nice. props for the custom work. gotta love "donated" material down with the man!
if you look at the 2nd pic to the left theres a piece of aluminum bolted to that tb which the tps mounts to. its there you just cant tell cuz the background is black.
vac lines will run out the bottom of each tb to a canister to run the map sensor.
air temp sensor will be on the bottom of the first tube also.
the last one i built ran fine without idle control so hopefully this will too.
i tune with an aem ems also
Old Feb 13, 2006 | 12:13 PM
syntax.'s Avatar
nice, ill be curious to see the final numbers it makes
Old Feb 13, 2006 | 12:20 PM
2lude4u's Avatar
That's definately some nice work, unlike most DIY Itb's.
I'm curious how having the actual butterfly plates so close to the head effects the dynamics of the airflow? I always assumed you want the plates generally further away from the head.
Old Feb 13, 2006 | 12:22 PM
Don Jefe's Avatar
Default Re: Pics of my new ITB manifold -- built by me (2lude4u)
Jesus, beautiful work my friend. Hopefully it makes a lot of powah! Great job on those bad boys.
Old Feb 13, 2006 | 12:40 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u &raquo;</TD></TR><TR><TD CLASS="quote">That's definately some nice work, unlike most DIY Itb's.
I'm curious how having the actual butterfly plates so close to the head effects the dynamics of the airflow? I always assumed you want the plates generally further away from the head.</TD></TR></TABLE>
well you could be very right on that. my last design did use the tb's further up in the tube but was more complicated and took more pieces. i've seen it both ways as with the fuel injector placement too. i think the blade is far enough back and the port is deep enough in the head that it wont affect the air too much as its curving down into the cylinder. the flange is angled too (you cant see it in the picture) but when at full throttle the airflow path should point directly towards the valve.
Old Feb 13, 2006 | 12:46 PM
AngryJeremy's Avatar
it seems like the extra turbulence caused by the butterfly valve located that close to the injector would help stir up the fuel resulting in better combustion. I LIKE IT
Modified by AngryJeremy at 2:31 PM 2/13/2006
Old Feb 13, 2006 | 12:50 PM
The_Sober's Avatar
I have wood...
Old Feb 13, 2006 | 01:20 PM
98vtec's Avatar
moderator emeritus
Default Re: Pics of my new ITB manifold -- built by me (The_Sober)
very nice....makes me sad that mine will turn out nothing like that
Old Feb 13, 2006 | 01:58 PM
PrecisionH23a's Avatar
Very sexy
If it performs as well as it looks you should consider manufacturing these.
Old Feb 13, 2006 | 02:29 PM
prelude1897's Avatar
Nice
Old Feb 13, 2006 | 02:53 PM
J7OWN's Avatar
Default Re: Pics of my new ITB manifold -- built by me (prelude1897)
Wow ... post pics of the install.
championshipwhite93si's Avatar
hey you think if i sent you a manifold from an h23 you could hook me up with a set of those
Old Feb 13, 2006 | 03:58 PM
LudeyKrus's Avatar
It looks amazing.
Let us know what your numbers are when you get dyno'd
Old Feb 13, 2006 | 05:42 PM
The Birdman's Avatar
Default Re: (LudeyKrus)
looks good man! Props for the hard work
Old Feb 13, 2006 | 06:19 PM
Partizan's Avatar
looks awesome
Old Feb 13, 2006 | 06:22 PM
94vtirozguy's Avatar
Default Re: (Partizan)
very nice
Old Feb 13, 2006 | 06:47 PM
98vtec's Avatar
moderator emeritus
Default Re: (silverlude15)
they look as long as any other DIY itb
Old Feb 13, 2006 | 07:30 PM
skunked's Avatar
Default Re: (98vtec)
NICE
Old Feb 13, 2006 | 11:02 PM
@ries's Avatar
Default Re: Pics of my new ITB manifold -- built by me (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Very sexy
If it performs as well as it looks you should consider manufacturing these.</TD></TR></TABLE>
agreed... please keep us posted on the results.
Old Feb 13, 2006 | 11:26 PM
hu's Avatar
hu
Looks great. Looks like good quality stuff.
