Seats are in, well not quite....*pics*
Got them in, the problem is they are only holding up with 2 bolts on the outer side.
I'm gonna do some welding, weld the extra bracket so i can bolt up 3 bolts. The one at the back will have to leave it out. Unless someone else has any better ideas.
Throw them in. I got the rears too which require mods as well.
Here are some pics.
Here are some pics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Groove_D »</TD></TR><TR><TD CLASS="quote">Thanks, too bad i got a DA. My rear mounts for the seat are a bit different.
oops sorry
oops sorry
It helps a little bit, thanks man. But the guy hasn't done it himself. All i see on his pics that he cut the ears/brackets from the teg rails and welded those ears/brackets to the RSX rails. And the rear mount, the hole was just offset and redrilled. The inner one not sure how it was done.
