Is still GM Synchromesh the best fluid for our transmissions?
Old Feb 13, 2006 | 10:41 AM
iNetForce's Avatar
Default Is still GM Synchromesh the best fluid for our transmissions?
I will be getting an used si transmission very soon and I want to know what kind un fluid is best to use.
Old Feb 13, 2006 | 10:46 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (iNetForce)
i am very happy with honda manual transmission fluid in my si transmission. i think the conclusion of the 30 page thread on the subject was something to the effect that all the manual trans fluids are essentially the same.
Old Feb 13, 2006 | 11:07 AM
Boosted Chemist's Avatar
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (sanimalp)
gm snycro takes away grinds like magic, also a cheeper alternative is penzoil syncromesh, its at autozone and ive have good results with it
Old Feb 13, 2006 | 11:30 AM
esteen2's Avatar
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (Boosted Chemist)
You can contact someone with Rocket motorsports, Rocket has a magic blend of fluid that gets rid of grinds and makes shifting smoother. (www.m24x.com)
Old Feb 13, 2006 | 11:34 AM
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (S2R Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2R Honda &raquo;</TD></TR><TR><TD CLASS="quote">You can contact someone with Rocket motorsports, Rocket has a magic blend of fluid that gets rid of grinds and makes shifting smoother. (www.m24x.com)</TD></TR></TABLE>
never knew that, any more info?
Old Feb 13, 2006 | 11:58 AM
esteen2's Avatar
You can go to m24x.com or I think there are a few dealers on H-T including Rocket himself. I use the fluid and it's made a great difference, had a 1st to 2nd grind when shifting at high rpm's now its gone.
Old Feb 13, 2006 | 12:07 PM
crxnj's Avatar
I use pennzoil syncromesh..No problems with it..
Old Feb 13, 2006 | 12:24 PM
ghost_ryder35's Avatar
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (Mr.speaker)
i used gm synchromesh. if i had known that pennzoil was about $10 cheaper a bottle and the same thing I would have gotten it instead. what are you going to do though you know. GM SYNCHROMESH or the PENNZOIL SYNCHROMESH are the best in my opinion.
Old Feb 13, 2006 | 12:50 PM
crxtreme89h's Avatar
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (ghost_ryder35)
10 W 30 works fine here.
Old Feb 13, 2006 | 01:14 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">10 W 30 works fine here.</TD></TR></TABLE>
I know the manual says to use that but is it alittle rougher shifting with 10w30 then wih mtf??
Old Feb 13, 2006 | 01:28 PM
downest's Avatar
I use 10w30 too, it's fine. As long as you push the clutch all the way in, I don't see how you would have any problems shifting.
Old Feb 13, 2006 | 01:39 PM
Pee Wee's Avatar
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (downest)
i think im the only idiot using royal purple tranny fluid.
Old Feb 13, 2006 | 02:19 PM
ewaugh's Avatar
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (Pee Wee)
No, your not.
Old Feb 13, 2006 | 04:46 PM
Custom Rex's Avatar
Default Re: Is still GM Synchromesh the best fluid for our transmissions? (ewaugh)
GM SYNCHROMESH
Bryanb
Feb 12, 2014 09:48 AM
justBrowsing
Honda Civic (2001 - 2005)
Oct 30, 2011 02:03 PM
singher01
Jul 25, 2008 10:19 AM
accordinglyevil
Aug 5, 2004 11:46 AM
EG6[B16A1]
Aug 23, 2003 08:46 PM
