EG VX steering knuckles fit EF DX?
Old Feb 13, 2006 | 08:20 AM
Minor Threat's Avatar
Default EG VX steering knuckles fit EF DX?
Searched and looked through the FAQ to no avail.
My wheel bearings need replacing, and I can't have the car off the road for any length of time, so I'm trying to pick up a spare set of knuckles. I've got an offer of free steering knuckles/hubs from a 92 VX, but I can't figure out if they'll fit or not.
Can somebody clear this up?
Old Feb 13, 2006 | 08:57 AM
Nerologic's Avatar
they will work...
BUT
your camber will go to ****, so ur tires wont last long...
but if u need a temp fix, that works
Old Feb 13, 2006 | 09:00 AM
VtecSyndrome's Avatar
Default Re: EG VX steering knuckles fit EF DX? (Brett Roger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brett Roger &raquo;</TD></TR><TR><TD CLASS="quote">Searched and looked through the FAQ to no avail.
Can somebody clear this up?</TD></TR></TABLE>
The geometry is totally off, don't use these. The wheel bearing may be the same size but if you press it out then you won't be able to reuse it in the EF spindle.........So no it won't work. 90-93 Integra or 88-91 EF spindles, don't go w/ anything else
Old Feb 13, 2006 | 09:04 AM
Nerologic's Avatar
Default Re: EG VX steering knuckles fit EF DX? (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">
The geometry is totally off, don't use these. The wheel bearing may be the same size but if you press it out then you won't be able to reuse it in the EF spindle.........So no it won't work. 90-93 Integra or 88-91 EF spindles, don't go w/ anything else</TD></TR></TABLE>
the geometry is totally off because the top arm is about an inch longer...
it will work if he needs something temporary...
but like i stated the camber will go very bad...
i personally did this for a few weeks because i had no other options...
tuerka_racing1
Sep 23, 2008 06:21 PM
FTW_Performance
Apr 4, 2008 08:00 PM
scuzz
Dec 10, 2007 05:07 PM
B16A JDM EG
Nov 22, 2006 07:38 AM
hondafrk
Oct 24, 2004 02:48 PM
