k sport adjustable coilovers?
Old Feb 13, 2006 | 08:14 AM
crix868's Avatar
Default k sport adjustable coilovers?
my boys shop told me i should go with the K SPORT fully adjustable coilover suspension for $800 is this kit really worth it i have listed the specs please let me know if its worth it to go ahead an get this thanks alot
FEATURES:
Spring Rate Front: 15 kg/mm - 838 lb/in
Spring Rate Rear: 9 kg/mm - 503 lb/in
Fits All 94-01 Integra exc. Type-R
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
Optimized combination of spring rate and dampening for the ultimate street ride.
3 Locking perch mechanism (2 for spring height, 1 for body height)
Adjustable Strut Body Length allows you to adjust the height of the strut without suffering the loss of full strut extension
Rubber Dust Sleeve protectors on each strut to ensure durability by protecting strut against contaminants
0"-4" Adjustable Height
Built with Highest Quality Billet Components
Fully Rebuildable Strut
100% Brand NEW
eg6sir88
Suspension & Brakes
Aug 22, 2007 06:07 PM
GUA-D'zCb-7
Jun 5, 2007 05:58 PM
GroundZer0
28
Jul 30, 2003 04:13 PM
TypeSH
Mar 28, 2002 06:28 PM
