Rear Suspension Problem
Every time I take the corners hard on my car, I hear the rear suspensions creak a lot. after about 5-10 hard corners, I would hear a lot of creaks and noises coming from the back even if I turn normally. Also a ticking/rattling sound appears(kinda like a metal ball bearing which is rolling freely in a small metal box making rattling sound).
But all of this noise will go away probably after 3-5 hours of parking my car. If I drive it even harder, It will take longer before the noises disappears........
Im not sure what is wrong, or is it normal? Im not sure how the suspension assembly is designed, I might take a peek at it tonight. You guys got a clue?
Bushings wont be shot. Just installed th ITR sway bar and used new d bracket and endlink bushings. Or are you talking about the metal part on the lower control arms?
dont feel bad. my car is an 01 gsr and i did type r suspension conversion on it. i blew a new shock in less than 8000 miles. open the trunk and press down on it. if you hear like a "watery" sound or bad creaking its prolly the shocks or shock
I don't hear watery....But when Im riding the trunk and pushing down on it reall hard then I get very few creaks. Its hard to get them to creak real loud when the car aint moving, thats why I could never pin point it. Oh my car has only done 60k thou...
Yeah It was new....Yeah I forgot to grease the bushings.....But the creaks was already there even before the sway bar install
I
have u ever replaced the shocks? if u didnt id bet that what it was
Im planning on koni yellows when I get the money....I'll either go for whiteline, eibach or king springs.......maybe an apexi springs too.
mouab18c1
Nov 15, 2012 11:25 AM
