'88 crx si
Old Feb 13, 2006 | 07:13 AM
aimmotorsports's Avatar
Default '88 crx si
what would it take to make the stock motor make about 200 hp at the wheels on all motor? is it possable or just do a engine swap? i am new to hondas...
Old Feb 13, 2006 | 07:24 AM
CRX Toad's Avatar
Default Re: '88 crx si (aimmotorsports)
I would put a B-series or K-series swap in.That will get you to 200whp easy.
Old Feb 13, 2006 | 07:35 AM
Jonknee's Avatar
Put in a d15b1 and call it a day
Old Feb 13, 2006 | 07:45 AM
x_outlaw_x's Avatar
200 whp is NOT possible all motor with the stock crx si engine
Old Feb 13, 2006 | 08:39 AM
crxtreme89h's Avatar
Default Re: (x_outlaw_x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">200 whp is NOT possible all motor with the stock crx si engine</TD></TR></TABLE>
Can you back that up?
Old Feb 13, 2006 | 08:46 AM
crxnj's Avatar
Default Re: (crxtreme89h)
I bet you can make it hit 200whp ..
Run very high compression,Huge camshaft,oversized vavles and custom intake manifold,,Good tuning,and rev it out..And you'll need some good fuel..
I dont think it would be worth it though..not to me atleast..I'd be happy with 130-140whp d16a6 engine..And even that is a task..
Old Feb 13, 2006 | 09:38 AM
Default Re: (Mr.speaker)
It would be a huge task to pull another 92+ real HP out of an a6, however I am sure someone has done it.
Old Feb 13, 2006 | 09:44 AM
x_outlaw_x's Avatar
can you prove it the other way?
Old Feb 13, 2006 | 09:57 AM
No. But it would be easier to prove that it has been done than for you to prove that it has not been done.
Modified by crxtreme89h at 7:32 PM 2/13/2006
Old Feb 13, 2006 | 10:33 AM
x_outlaw_x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">No. But it would be easier to prove that it has been done than for you to prove that it has not been done. BTW my dick is bigger than yours. </TD></TR></TABLE>
probably
Old Feb 13, 2006 | 10:34 AM
x_outlaw_x's Avatar
but i have seen an all motor d16z6 make about 175 though
Old Feb 13, 2006 | 10:50 AM
Vovchandr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aimmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">what would it take to make the stock motor make about 200 hp at the wheels on all motor? is it possable or just do a engine swap? i am new to hondas...</TD></TR></TABLE>
Dude, listen, my fart has bigger displacement then the stock 1.6L engine, so making 200 wheel hourse out of it NA, would be extremely costly, there is no reason to try to reach that goal unless you want some braging rights, while people who spend less then you will smoke you.
There is a reason why most people swap motors and or turbocharge the motor.
Swap and or turbo is the only cheap/good/proven way to make over 200whp on a crx.
Boosted stock motor however, tuned right, protected from knock, and in good overall shape/condition can hit 200whp
Old Feb 13, 2006 | 05:17 PM
Jonknee's Avatar
Default Re: '88 crx si (Vovchandr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vovchandr &raquo;</TD></TR><TR><TD CLASS="quote">
Dude, listen, my fart has bigger displacement then the stock 1.6L engine.</TD></TR></TABLE>
I love you man haha
Old Feb 13, 2006 | 05:21 PM
Pee Wee's Avatar
Default Re: '88 crx si (efnewb91)
Boosted stock motor however, tuned right, protected from knock, and in good overall shape/condition can hit 200whp</TD></TR></TABLE>
yeah ok , but alot of the swaps are b16's, so your fart comment carries no weight, just stench
Old Feb 13, 2006 | 05:53 PM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">It would be a huge task to pull another 92+ real HP out of an a6, however I am sure someone has done it. </TD></TR></TABLE>
I thought I remember someone doing it a while ago. Around 215WHP out of a d16a6. If I remember correctly, they had it bored over a good amount, were running a dry sump, ITBs, etc.
If you can make a b16a produce 200WHP with off the shelf parts, I think 200WHP in a d16a6 is very possible.
crxhoutx
Mar 28, 2005 10:36 AM
Dude87
May 31, 2004 12:23 PM
Bobby12many
Mar 26, 2004 11:09 AM
1gen crxer
13
Mar 4, 2004 03:18 PM
RATEDR
Feb 21, 2002 07:43 AM
