WTB: b series bottom end or longblock
LS block with oversize ctr piston only has 2k miles on them 500 plus shipping..comes with alternator starter water pump oil pump and vtec oil line
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic »</TD></TR><TR><TD CLASS="quote">B16A2 longblock, needs rings. $100</TD></TR></TABLE>i think you ment short block
here you go... perfect lsvtec setup.. http://hondamarketplace.com/zerothread?id=1526147
buitl ls bottom end, 9:1 compression, je pistons,eagle rods/blancaed blueprinted, the works, $2250shipped.
0 miles have many pics.
I can also put a b16 head on it, and make it a long lock, its whatever you need.
Also have Stock ls bottom ends and B16, Built and Stock,
Are you looking for high/low compression or built/stock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klubhed1 »</TD></TR><TR><TD CLASS="quote">thouhtt u needed a whole longblock.. wow</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brent_G »</TD></TR><TR><TD CLASS="quote">bump. Really just want a longblock so i can swap in and get on the road again. </TD></TR></TABLE>
I have a built B16A. Resleeved with Darton Sleeves, JE Pistons 9:1 Compression, Eagle H-Beam Rods, Eagle LS Crank, ACL or King Bearings. Motor Bored to 84mm, Stroked to 89mm. Motor blueprinted and balanced. All work was done by ARI, out of Jupiter FL. $1800.00. All parts cost $2500 and machine/assembly work cost $1800. Never been run with this set up.
I also have the head, if needed.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx34 »</TD></TR><TR><TD CLASS="quote">I have a built B16A. Resleeved with Darton Sleeves, JE Pistons 9:1 Compression, Eagle H-Beam Rods, Eagle LS Crank, ACL or King Bearings. Motor Bored to 84mm, Stroked to 89mm. Motor blueprinted and balanced. All work was done by ARI, out of Jupiter FL. $1800.00. All parts cost $2500 and machine/assembly work cost $1800. Never been run with this set up.
Thanks</TD></TR></TABLE>
thats a nice offer but too far outta my range.. need something under 800 ish
