DA engine mount question
Old Feb 13, 2006 | 04:07 AM
BGWarren's Avatar
Default DA engine mount question
if been trying to find my answer but no luck
question is can i used DCs upper/lower driver side engine mount, and would it bolt/align up with the DAs chassis engine mount??
im switching my b17 for a C5, and i have its driver side engine mount so i wonder if it'll work or do i need to use my old upper/lower engine mount from the 1.7
does anyone know this??
thanks BGW
Old Feb 13, 2006 | 06:19 AM
92db2's Avatar
Default Re: DA engine mount question (BGdubs92b17)
I believe you would just use the mounts from your b17. they should work. you may have to use the one that bolt on under the timing cover also. so you may want to keep them handy just in case you need them. i know i had to switch them all over, when i did the b16a swap in my last integra (90 gs). i found out the hard way about it. and then realized that i needed the b18 mounts and then it fell right in.
later
casey
B00M3R
Feb 17, 2010 02:02 AM
fastcrx420
Oct 25, 2009 04:48 AM
Civic168
Suspension & Brakes
Feb 28, 2006 09:21 PM
marc-111
Jan 25, 2006 11:37 PM
2000DX
Jun 23, 2004 11:15 PM
