H22 modified oil pans for ground clearance?
Old Feb 13, 2006 | 02:12 AM
djnikko's Avatar
Default H22 modified oil pans for ground clearance?
Does anyone know a vendor that sells H22 oil pans which give more ground clearance?
Thanks
Old Feb 13, 2006 | 12:53 PM
h22 civic's Avatar
Default Re: H22 modified oil pans for ground clearance? (djnikko)
call z10 motorsports they make custom pans
Old Feb 14, 2006 | 08:12 AM
djnikko's Avatar
Default Re: H22 modified oil pans for ground clearance? (h22 civic)
I shall send them a mail as I am overseas but thankyou for the contact.
Has anyone mocked up one themselves in the past? If I had a spare sump lying around could I modify it to be a slightly shorter kick out sump. Im only looking to lose about half an inch, so may not need to do the kick out part. If I run an oil cooler with no thermostat could this make up for the lack of volume in my sump?
oil sump means oil pan, not sure if this was an english term.
This is an attempt to gain a little more ground clearance on a h22 CRX conversion
Old Feb 16, 2006 | 04:54 AM
djnikko's Avatar
bump for more info!
.BigSexy
Apr 7, 2007 07:52 AM
EDANSiR
Sep 13, 2006 05:36 PM
crj_lll
Apr 15, 2006 01:52 PM
djnikko
Feb 11, 2006 10:14 AM
Myh4tch
Jul 20, 2004 06:02 AM
