Suspension & Brakes Theory, alignment, spring rates....
ITR Rear Upper Control Arm Q.
Old Feb 13, 2006 | 01:59 AM
hypeR speed's Avatar
Default ITR Rear Upper Control Arm Q.
Previous owner of my car screwed in the 2 rear upper control arm bolts at the wrong angle and screwed up the threads on the nut holding the bolt in.... that nut is on the other side of the subframe and is not accessible from the outside ... at least i dont think it is... whenever i go over a bump the upper control arm taps the wheel well and makes a super annoying click... would drilling and filling in the nut with thread repair compound thats rated for upt o 128 ft lbs of torque work or would i have to use a tap n die set with a threaded insert ? Is that reliable enough for the amount of stress it has to endure... if not how do i fix that nut?
Old Feb 14, 2006 | 10:25 AM
Default Re: ITR Rear Upper Control Arm Q. (res09ggm)
nebody?
Old Feb 14, 2006 | 11:16 AM
Tyson's Avatar
yeah youre pretty much screwed if those threads are messed up. (hmm... no pun intended). have you tried chasing the thread with a tap?
ive heard of ppl having to cut a hole to get to it and weld a new nut on. sucks.
Old Feb 14, 2006 | 05:05 PM
chrisw85's Avatar
i believe those two nuts holding the inner upper part of the upper rear control arm are accesible from teh inside if you take off the plastic covering that rear qtr panel area
Old Feb 15, 2006 | 11:25 AM
Default Re: (chrisw85)
i dont believe it is... my car's gutted as it is now and it doesnt seem acccessible from the inside...
Old Feb 16, 2006 | 07:31 AM
danvuquoc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by res09ggm &raquo;</TD></TR><TR><TD CLASS="quote">Previous owner of my car screwed in the 2 rear upper control arm bolts at the wrong angle and screwed up the threads on the nut holding the bolt in.... that nut is on the other side of the subframe and is not accessible from the outside ... at least i dont think it is... whenever i go over a bump the upper control arm taps the wheel well and makes a super annoying click... would drilling and filling in the nut with thread repair compound thats rated for upt o 128 ft lbs of torque work or would i have to use a tap n die set with a threaded insert ? Is that reliable enough for the amount of stress it has to endure... if not how do i fix that nut?</TD></TR></TABLE>
I would helicoil it and retap -- but I don't exactly know how strong that is. I've heard most people say it's stronger than the original threads.
Old Feb 17, 2006 | 06:55 AM
94rs-turbo's Avatar
you can onyl reach those from the outside but they are easy to retap, just make sure you have the right size when you tap it and you will be fine had to do that to 2 of mine as well
mymomsdrunk
Mar 5, 2008 08:38 AM
ActiveAero
May 14, 2006 10:22 AM
dem0nk1d
Apr 4, 2006 08:30 PM
Hyb
Feb 2, 2005 05:55 PM
