i just bought the jdm corner lights need help
From: Why so you can pretend like youre interested, FL/OK
Go outside and take a look at your car. This won't be difficlut for you. It's one screw and pulling your corner lights forward to remove them. Install is reverse.
No. It's just one screw. Just go outside, lift up the hood and take a look. When you pull out the corner light, just twist the corner light bulb harness to the left and pull out to remove the bulb and wiring. Again, install is reverse.
Vampire2o9
Aug 12, 2009 12:11 PM
