cam question
Old Feb 12, 2006 | 09:32 PM
hks_Racing's Avatar
Default cam question
is it true that if you buy after market camgears you have to buy camshafts too??
Old Feb 12, 2006 | 09:56 PM
YeuEmMaiMai's Avatar
Default Re: cam question (hks_Racing)
no. you can use cam gears on your stock cams
Old Feb 12, 2006 | 10:45 PM
hks_Racing's Avatar
Default Re: cam question (YeuEmMaiMai)
would that effect the performance or no?
Old Feb 12, 2006 | 10:48 PM
Crono139's Avatar
Do you mean for better, or worse?
With a cam gear, you can retard, or advance the timing. Either will improve your numbers on one end of the powerband, but you will lose power in the other.
At the stock setting, you won't experience any gains, or losses.
Old Feb 12, 2006 | 11:54 PM
hks_Racing's Avatar
Default Re: cam question (Crono139)
so theres pretty much no point on buying any unless u got some performance camshafts right
Old Feb 12, 2006 | 11:59 PM
Crono139's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hks_Racing &raquo;</TD></TR><TR><TD CLASS="quote">so theres pretty much no point on buying any unless u got some performance camshafts right</TD></TR></TABLE>
Not necessarily.
An upgraded camshaft will help, but you can still experience decent gains from a cam gear. It helps shift your powerband, and it does it nicely.
Old Feb 13, 2006 | 12:00 AM
iam7head's Avatar
pretty much a yes if you have a street car.
groupA nailed it for you
Old Feb 15, 2006 | 09:33 PM
hks_Racing's Avatar
Default Re: cam question (iam7head)
thanks
StraightNoChaser
May 31, 2008 04:17 PM
DaInFaMMuS1
May 2, 2008 02:37 PM
2point3h22lude
Jun 11, 2005 11:56 AM
jedubz
10
Feb 2, 2005 04:53 AM
HONDA-2NR
Mar 13, 2004 09:49 PM
