DA AXLE FOR A JDM CRX SIR?
Old Feb 12, 2006 | 09:09 PM
whiteef-8's Avatar
Default DA AXLE FOR A JDM CRX SIR?
i've searched but i got different information from everyone.
but i was wondering what axle should i use for a JDM CRX SIR w/b16.
i've read i could use the DA axles. non abs or abs dont matter, is this true?
So Da integras axles are the axle i should use?
Old Feb 12, 2006 | 10:30 PM
RCautoworks's Avatar
Default Re: DA AXLE FOR A JDM CRX SIR? (whiteef-8)
Which half shaft are you using ?
http://web.archive.org/web/200...s.htm
Old Feb 12, 2006 | 10:49 PM
whiteef-8's Avatar
Default Re: DA AXLE FOR A JDM CRX SIR? (90blackcrx)
i just read that site, and they said both would fit, so which do you guys recommend that would be easier?
Old Feb 12, 2006 | 11:27 PM
Hamstr323's Avatar
I am using 99 gsr axels no problems
you just need the matching half shaft
Old Feb 13, 2006 | 08:47 AM
crxtreme89h's Avatar
Most used combination would be 90-93 Integra LS NON abs Manual Axles with a 90-93 Integra Manual Intermediate Shaft. AKA Jack Shaft, AKA Half Shaft.
Old Feb 13, 2006 | 08:51 AM
crxnj's Avatar
Default Re: DA AXLE FOR A JDM CRX SIR? (crxtreme89h)
Yeah if I were you I would just get the 90-93 integra halfshaft and make your life easier..
How it is right now though with the sir halfshaft you can use the 90-93 integra axle(most b-series will work on passenger side) on the passenger side but on the driver side you have to use 88-89 integra inner joints with the 90-93 outers..
Old Feb 13, 2006 | 08:53 AM
Default Re: DA AXLE FOR A JDM CRX SIR? (Mr.speaker)
This link should help ya:
As far as what Mr. Speaker just said, I am using 90-93 LEFT and RIGHT Axles with my B16 and have had no problems for nearly 3 years now.
Old Feb 13, 2006 | 01:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteef-8 &raquo;</TD></TR><TR><TD CLASS="quote">i just read that site, and they said both would fit, so which do you guys recommend that would be easier?</TD></TR></TABLE>
It clearly states what to use.
Old Feb 13, 2006 | 02:32 PM
wu tang's Avatar
i run the DA non abs ones and they work great
Old Feb 13, 2006 | 04:03 PM
Rywire's Avatar
Default Re: DA AXLE FOR A JDM CRX SIR? (wu tang)
FYI everyone, abs axles make no difference... they fit the same in our cars
Old Feb 13, 2006 | 09:37 PM
Hamstr323's Avatar
Default Re: DA AXLE FOR A JDM CRX SIR? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">FYI everyone, abs axles make no difference... they fit the same in our cars</TD></TR></TABLE>
werd
Crxgeek1997
Dec 19, 2017 08:58 AM
aojtin
Apr 16, 2009 05:20 PM
border919
Nov 22, 2008 06:59 AM
philkehn
18
May 28, 2007 08:24 AM
nexgen91
Mar 26, 2006 08:44 AM
