SWAP ZC ON THE WAY (WHAT ARE ITEMS NEEDED)
i'm planning on swaping the SOHC ZC motor in the shell.
What are the items i need for the swap? When i get my crx back from the shop i am going to start saving and gathering parts for it.
But what do i really need tho. i already searched but i want more accurate and straight up ansers.
<U>What i have so far.</U>
SOHC ZC Engine
Fuel rails
MPFI
some kind of fuel injectors
No what else would i need? Please add or correct list if im wrong, i'm not all that sure.
Trans-
Axles-
Shift linkage -
ECU
Wiring Harness
Resistor box
Distributer
water pump
Alternator
Would parts from a 89 CIVIC DX 4Dr work?
Also what else would i need?
I already ran a search, that is where i got most of the needed parts from.
Modified by explictness at 8:27 AM 2/13/2006
Modified by explictness at 8:57 PM 2/13/2006
SOHC ZC Engine
Fuel rails
MPFI
Trans-
Axles-
Shift linkage -
ECU
Wiring Harness
Resistor box
Distributer
water pump
Alternator
anyone? please? lol or did i basicaly just hit everything on the button?
I think i found more items, will i need all this?
Ran anothe search, but im guessing parts listed is if you start from scratch or something???
Alternator Belt
A/C Belt
Timing Belt
Engine Mounts
Thermostat
Crank Seal
Rear Main Seal
Cam Oil Seals
Valve Cover Gasket
Radiator Hose Upper & Lower
Distributor Cap & Rotor
Exhaust Gasket
Water Pump
Oil Filter
Spark Plug Wires
Throttle Body & TP Sensor
ECU (Best)PM7
Spark Plugs
Head Gasket
Intake Gasket 8
Si Pressure Plate / Disk
Si Throw Out Bearing
Exhaust Header
Oil Pan Gasket
Cam Angle Sensor
Distributor
Modified by explictness at 10:59 PM 2/12/2006
Alternator Belt
A/C Belt
Timing Belt
Engine Mounts
Thermostat
Crank Seal
Rear Main Seal
Cam Oil Seals
Valve Cover Gasket
Exhaust Gasket
Water Pump
Oil Filter
Spark Plug Wires
ECU (Best)PM7
Spark Plugs
Head Gasket
Intake Gasket 8
Exhaust Header
Oil Pan Gasket
Cam Angle Sensor
Distributor
common guys i need to know.
